Naturally Aspired 95', what else can I do?
loud95sse
- Year and Trim: 1995 bonneville sse, no S.C.
I am wanting to add some more horse to my 95 bonnie. I have already a 9" K+N intake, a ZZP HV3 insert, and a high-flow muff.
I want the ZZP L36 HV throttle body next. Other than that is there any thing else I can do for some horse? Will the L36 PLOG from ZZP work on the Bonneville? Would it be worth it to get a ZZP downpipe with high-flow cat.
Naturally aspirated 95 bonneville sse. HV3 insert, 9" k+N cold air intake, Hi-flow muff, new metallic paint, 16" chrome rims, tinted tails.
I love Alpine. Alpine cd player, 15" alpine type R w/ alpine mrd-m1005 amp. more to come.
Comeing soon: hi-flow TB, PCM, maybe rockers.
bonnevillain
- Year and Trim: 2002 SLE
Re: Naturally Aspired 95', what else can I do?
the high flow muffler wont gain you anything, I would stick with the PLOG, downpipe and high flow cat. You will feel those differences, but if you really want to add some power, get rockers or a cam.
- repinS
- Moderator
- Year and Trim: 09 G8 GT
Moved to Performance and Brainstorming.
loud95sse
How much work is it to change the cam? I'm guessing not to easy. only $299 if I can do it myself.
- 95naSTA
- Year and Trim: 95 SLE
Its not too bad.
I did mine only after doing an HVII.. I used the HVII instructions and an L67 cam install write up as a guide. You'll have the drop the p/s subframe a little to get the cam out through the wheel well..
And you'll need a cam install kit with a new chain/damper, all the fluids, RTV, etc. So factor that into the cost.. It would be a good time to do springs/retainers at that point too.
P.S. The ZZP GT1 cam is your best choice hands down.
loud95sse
great info., thanks. I will talk with the local club to see if I will have help someday with it. I want to pump this N/A up to see 14's someday.
Add porting the lower intake to the list as well..
- LeSabreUltra
- Posts like a Northstar
- Year and Trim: 2012 Nissan Maxima SV Premium
YES ^^Jrs3800 wrote:Add porting the lower intake to the list as well..
Biggest bang for the buck on an L36!
-Dan
_
_
__I n n o v a t i o n__T h a t __E x c i t e s
_
_
__I n n o v a t i o n__T h a t __E x c i t e s-
I just figure if you are going to do a cam you might just as well get the benefit of a little extra flow..
loud95sse
Would that include taking off the LIM and taking it to a machinist. kind of new, what exactly is porting? Making bigger holes my guess?
- gonzo4191
- Year and Trim: 91 S10 P/U
97 SSEI- 136k - Location: round lake beach, IL
loud95sse
Anyone no where I could get a custom PCM burnt for this, and poss. the cost?
- LeSabreUltra
Best thing to do if you're knowledgeable about that sort of thing is get HP Tuners and do it yourself. If not ZZP or Intense can do one for you.
-Dan
_
_
_
_
__I n n o v a t i o n__T h a t __E x c i t e s- gonzo4191
doesn't the 95 have the weird way of tuning, maybe i'm wrong
95 Uses an EPROM... Usually people with the 95 L36 just go to Sinister Performance for their EPROM burns... Great group and easy to deal with..
Also keep in mind anytime you start to mod, there is a possibility that your modding can turn to this...
loud95sse
which out of the mods talked about on this topic are the most risk for damage. You are right I don't want to be walking.
I guess it depends on how hard you drive the car...
When that motor went I had the Ported Lower intake, Intense Fender Well Intake kit... ZZP PLOG( Performance Exhaust Manifold ), High Flow cat...
The motor before was only minus the PLOG.. I ran it hard and Piston slap is what finished it off..
I am on the 3rd motor.. It still had the Ported lower, High flow cat and Intense Intake..
Down the road I will consider a series III L26 with a mild cam and 3.29 gears and may invest in another PLOG..
The only thing I was trying to tell you is you have to pay to play, and sometimes your engine will not be forgiving..
I am also curious as to what the build date is on your 95...
