wow, maybe nix on the Xplodes
ga93sle
Year and Trim: 06 Grand Prix LS4
Post by ga93sle »
I was looking at a couple Sony Xplode amps the other day when pondering on my temporary WalMart system. Then I arrive at work today to find my friend and a couple of his buddies frantically pulling his box out of his truck after his Xplode amp went up in flames. :eek2:
*Chris*
15 Nissan Altima 2.5SL/2004 Honda Shadow 750 Aero
Previous, 07 GP SE, 06 GP GXP, 97 SSE 40th, 96 LeSabre Custom, 93 SLE, 90 LeSabre Custom
yourgrandma
Year and Trim: '02 SSEi
Re: wow, maybe nix on the Xplodes
Post by yourgrandma »
Sony is garbage, dude. There are far better brands out there that are cheaper and are not known to burn your car down. That said, I'm sure there was something wrong with the way their system was set u, most likekly too high valued fuse and drvers connected in such a fashion that impedence was too low. Memphis is where I put my Amp money and Image Dynamics made my subs.
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
x2 on the memphis - great speakers and awesome amps!
fastblackbeauty
Year and Trim: 1994 Black SSEi
Post by fastblackbeauty »
I agree on the Sony. Had an Xplode amp for all of three days...tossed it for a P. Gold.
"Black Beauty"
So I ask him, what would the right price be? He tells me about six grand. I shouted back Are you serious??? Nobody would pay that!!! With an old man evil grin, he smiles and says, I know.
1994 Black SSEi, fully loaded, best $400 car I have ever owned;
1990 Ford Taurus SHO, currently needing a motor transplant :(
Bugsi
05 Mercedes S500 4Matic
Post by Bugsi »
As a former master amplifier technician, yeah, you can do a whole lot better than Sony for any audio gear, period. (Seems "Xplode" is appropriately named.)
-Mark
`05 Mercedes S500
Red Rocket
Post by Red Rocket »
They named that line "Xplode" for a reason. :wink:
Sony makes horrible car audio. If you have the money, go with Kicker, Alpine, or a non-commercial company.
Audio: 12" Alpine Type R in 2.3 cu. ft. box tuned to 31 hz, Audiobahn A8000T, Rockford Fosgate 3sixty.1, Kicker wiring
Mods: Cross drilled and slotted rotors, hopefully more to come soon
ga93sle
Post by ga93sle »
I never was a fan of their speakers, subs, or decks, and I knew there was no way in he11 that I was putting any of that in my car, but I saw the amps and thought "maybe they won't be so bad".
*Chris*
GMC Guy
Year and Trim: 1999 Bonneville SSEi
Post by GMC Guy »
i like the Memphis speakers i was going to get a Memphis belle amp but the store i deal with stopped doing audio
Tinted 13% Front 3% Rear, MSD Coils and Wires, K&N drop in air and oil filter...more to come as things wear/break!!
Tint it so dark, you won't even know your name
Bugsi
Post by Bugsi »
Honestly, when it comes to amplification, there's only a couple ways to build an audio amplifier. The options pretty much boil down to: Tube -vs- Semiconductors, and in a car, we'd be talking about semiconductors. That splits into: Class A, class A-B, or Class D. For a car, we're usually dealing with Class A-B, unless you can afford really good Class D stuff. In Class A-B, that splits into discrete -vs- integrated. Purists will prefer discrete, but a lot of inexpensive amps will use integrated amplifier chips. Technically, it doesn't really matter, as it is possible to build a linear, low-distortion, high-gain amplifier using either technique, but that doesn't mean that everyone DOES. Still, distortion in even the cheapest car amps on the market will generally be lower that what you can hear, because designing an audio amplifier with rock-solid linear response just simply isn't rocket science, and hasn't been since about 1960.
So in the end, it pretty much boils down to the physical construction of the amplifier. They're generally mass-manufactured by machines, using the least expensive component available, with the least amount of materials possible. The worst offenders use cheap components with widely varying tolerances, that can't hold up under the heat that their application will produce, using poor quality solder connections with very small, thin traces, with very minimal protection circuitry since anything extra is just added expense. If anything goes wrong, this type of cheap amp will easily go up in flames. Amplifiers almost always fail by the output driver transistors short-circuiting (no matter if they're discrete or integrated, or whether they're BJT, JFET or MOSFET), and short-circuit failures are always the most destructive. Higher quality amplifiers will use higher quality, tigher tolerance components, and they'll have several different types of failure-mode protection circuits. They'll use thicker traces using more material, and have higher quality solder connections such as through-hole-plated double-sided-circuitboard soldering, and will use thicker wires and thicker heatsinks with more material, so there is a much larger safety-margin in its design. If anything goes wrong, say a speaker-wire short circuit, a better amp will have a protection circuit that can kick in and prevent the amplifier from destroying itself. A cheaper amp might advertise short-circuit protection, which can mean as little as "The amp has a fuse in it" -which might or might not blow before the amp destroys itself.
Sony, unfortunately, almost universally makes awful audio gear in terms of construction quality. Like almost any audio amplifier, theirs will sound as good or as bad as pretty much any other amplifier when it's working. Low quality amplifiers show their weaknesses under failure modes, and I would not expect Sony to fare well under those conditions. Flaming Xplodes don't surprise me one bit.
Sony makes some excellent quality video and digital camera gear. (They make some junk, too, as seems does almost everybody.) They're by no means at the bottom of the list for audio gear, but they're really really close. As I said previously, you can do a whole lot better than buying Sony audio gear.
-Mark
`05 Mercedes S500
ga93sle
Post by ga93sle »
Eclipse FTW. lol
*Chris*
Spl170s
Post by Spl170s »
started off on oldschool soundstream back when it was made good quality before they were bought out. then i ran a memphis audio setup on jl subs...loved it. the Mb quarts were nice in that setup too. now, i just look for a well built amp from a known manufacturer that isn't offered at places like best buy..haha. my truck install is waiting, i got a group of oldschool ppi powerclass amps for that setup and my IDQ 10's also. Going to run diamond audio comps in that setup also. i just need to get off my butt and install it. just got done with my install today in the bonnie. went with older us acoustics amps and my kicker oldschool solo-baric 15 sub. running diamond audio comp set up front and rear fill kenwood 6x9s...not bad...but something is up with my sub setup..not getting near as loud as it should be.
as for sony, i use to run there mobile ES decks, never a problem there...nice SQ. but as far as speakers and amps, never ever heard anything good there.
"You cannot legislate the poor into freedom by legislating the wealthy out of freedom.
What one person receives without working for, another person must work for without receiving.
The government cannot give to anybody anything that the government does not first take from somebody else.
When half of the people get the idea that they do not have to work because the other half is going to take care of them,
and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for,
that my dear friend, is about the end of any nation.
You cannot multiply wealth by dividing it."
~~~~~ Dr. Adrian Rogers, 1931 - 2005 ~~~~~
BonneMe
Post by BonneMe »
I've used sony ES stuff in installs before on a friend's firebird. It's been running @ 1kw 1ohm stable for oh 5 years and he's not really a car audio guy, just wanted some bump.
But normal Xplod stuff, you can do better.
TenGHz
Post by TenGHz »
My ex had an Xplode CD deck in her car. It never really sounded good, and felt kinda cheap. It stopped working right within a year or 2 of putting it in. Just felt cheaply made.
-Joshua-
lowrider0308
Year and Trim: 2006 Chevy Silverado LT
1989 Camaro RS LT1
Post by lowrider0308 »
Now, for something other than bashing of sony. I completely agree, that if your trying to win a competition, i wouldnt go sony.
But, with that said, I have a sony HU in my truck, sony 6.5's, and sony 4x6's. They are plenty loud for me, and stay pretty clear with the HU all the way up. They sony 6.5 3-ways KILL the Pioneers of the same specs and price. I had the pioneers in my truck for a month before I ditched them. Now I dont have components, and I'm not trying to win a competion or go deaf, but I have had no problems with my stuff. Take it for what its worth. I did go with a Kicker sub though.
--2006 Silverado LT-3/3 RCX Lift, Bilstien 5100's, CAI, Exhuast, BFG A/T's,
Tuners Inc. dynotune, Aeroforce Interceptor, Kicker 10" TC, iSimple Interface
--1989 Camaro RS-LT1/700r4 drivetrain swap, Corvette trans internals w/2200 stall,
rebuilt engine with LT4 cam
Spl170s
Post by Spl170s »
i think the biggest thing to remember here in the post is that alot of the xplode series of sony is just plain and simple their cheapest line possibly made to go to mass market "wal-marts and so on".
Is there better than sony, oh yes......by far. But to base all judgements of sony off of the crap that wally-world sells isn't a good judgement to make.
First and foremost, if your building a system off of the shelf at wal-mart...you kinda get what you pay for don't you think? i know it is a cheap, but as stated, in audio, you get what you pay for.
ga93sle
Post by ga93sle »
I have had absolutely no problem with my deck or speakers that were both purchased at Wal Mart. My friend on the other hand purchased a Sony deck through a local car audio place, and has had nothing but problems. And I have went in electronic stores that sold the exact same decks as the ones at Wal Mart. IMO, just because it came off a Wal Mart shelf, doesn't make it necessarily bad. Now if I were building a competition system, Wal Mart would be the last place on my list, but for everyday use, I have no issues.
*Chris*
Spl170s
Post by Spl170s »
as stated, all depends on tastes.
blackout
Year and Trim: 96 Bonneville SE
Post by blackout »
Just wanted to through my 2 cent in, sony never liked it all bad for me but there is a site were you can get alot of good stuff for real cheap and its all real and good.
http://ikesound.com/
96 SE Pioneer AVHP5700 head unit(ipod connection) new are intake, clear corners, new foglights. HID head lights (Soon to have new rims) as soon as it gets warm enough.
b18jason
Year and Trim: 99 Bonneville SLE,
Post by b18jason »
I've had a single Sony Xplode 12inch sub for about 3 years now and have never had a problem, and it sounds awesome and hits 125 or so dB with a Pioneer 760 watt 2 channel amp bridged (another Wal-mart special) The only problem i have is that sometimes when its hot out the amp will shut of for a few minuets but for what i payed i can't complain.
