need some help
sco99888
Year and Trim: 2001 se non supercharged
need some help
Post by sco99888 »
hello all,
my car started some new sysmtoms last week,when i put the car in reverse or drive it has a really heavy vibration coming from the right side of the engine or almost sounds like a machine gun,the crank shaft sensor has been triggering engine light i sont know if this is what happens then the sensor goes bad,also the car has a really foul smell,i changed all spark plugs,wire's & coils so i know it is not the spark.
thanks for any input,
scott
willwren
Re: need some help
Post by willwren »
Please get the codes read and come back here with them. Most auto parts stores will scan it for free. Without those codes, we could sit here for a month guessing at the problem and throwing parts at it.
sco99888
Re: need some help
Post by sco99888 »
2 weeks ago i scanned it,i had codes for crank shaft sensor,knock sensor 1&2,random miss fires,small fuel evap leak,i reset them,all was fine till last week (wendsday),car would not start i cranked it so much i killed the battery,i jumped it the next day started up then the engine light was flashing for couple min then stayed lit,when i put the car in gear it shakes really bad via the engine,and it smells horrible,i had the intake manifold gasket replaced 7 months ago it had all the same symptoms,i checked under the car and there was oily substance on the ground we had rain so i could not tell if it was oil or tranny fluid.before all this the car ran fine wendsday morning,then when i got it started all this was happening.
Archon
Re: need some help
Post by Archon »
Find out what codes are still there. If the crank sensor is one, that would be a good place to start.
