1995 Silhouette A/C troubles
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
L67Silhouette
Year and Trim: 1995 Silhouette Series II
Post by L67Silhouette »
I bought this van with the high speed blower relay burned out...I didn't find any obvious problems so I replaced the relay and the high speed worked fine for 6 months and the relay burned out again...Today, 6 months later, it burned up again...Any ideas?
John Deere Boy
Year and Trim: 1993 SSE
Member since Nov 2003
Re: 1995 Silhouette A/C troubles
Post by John Deere Boy »
The fan motor may be going bad and using too much current.
Post by Jrs3800 »
Same problem I have found on the 95 Transport...
And the same Issue I had on the 95 Bonneville of sorts... The Blower Motor on the Bonneville got bad enough that it fried the connector and the wire... I had to find a good one on a Junk car and splice the new connector in and replace the Blower Motor.... I have had no further wire cooking issues...
The 95 Transport has cooked the wire a little... And had melted the blower motor relay... I replaced it and will soon replace the Blower motor...
L67Silhouette
Ah goodie...One more thing to replace. ](*,) ](*,) ](*,) ](*,) ](*,)
