project 40th
Part it or fix it?
Part it out
21
30%
Fix it up and sell it
48
70%
Total votes: 69
trf_ssei
Year and Trim: 1998 bonneville SSEi
Re: project 40th
Post by trf_ssei »
harofreak00 wrote:Little faith you guys have... [-X
The trunk is pretty bad.
I'm thinking of welding in a steel plate there and mounting to that. Would even be sturdier than stock.
Same thing happned to mine i backed it with 3/16 flat bar and its solid now. i dont know how it ripped out tho cause there is no damage other than the latch being ripped out no rust either..
If it were quick and easy everyone would be doing it!
crzydmnd72
Year and Trim: 1999 SLE
Re: project 40th
Post by crzydmnd72 »
I have no doubt you could make it look like a babied 100k original. Question is, would it bring enough after fixup to make your labor worth it to you?
OT, you gotta share how you clean up a carpet. I tried a Bissell once on mine, didnt quite give me the results I was hoping for.
Glenn
1999 SLE 70k Stock for now
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Re: project 40th
Post by petraman »
Peterg22000 wrote:FIX IT!!!
Sorry, couldn't help but post this...
http://www.youtube.com/watch?v=yo3uxqwTxk0
2013 A4 P+ ------------------ Glacier White Metallic
6MT, Sport Pkg, JHM Stage 1 Clutch/LWFW, JHM Short Shifter, JHM HFC, USP SS Clutch Line, CR-15 Strut Bar, Alu Kreuz, BFI Shift Knob, EC Trans Mount Insert, VCDS tweaks.
Roadtech195
Year and Trim: 2007 Grand Prix GT
Re: project 40th
Post by Roadtech195 »
Part the pig out and get your money back. I think you could spend less effort in flipping a much better car while making more money.
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
biohazed
Year and Trim: 2000 Grand PRix GTP
Re: project 40th
Post by biohazed »
I think it could be a fun project car. I say fix it up and then sell it.
- 2000 Bonneville SE 3800 Series 2, Aluminum LIM Gasket, Dorman Improved UIM - Sold
alexcoqui
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Re: project 40th
Post by alexcoqui »
the car has to many miles on it to be worth all that work. If you want to fix it & keep it I say go for it, but if you want to make a profit... I dont see it hapening. Plus make shure that the engine & tranny are good before you start throwing money in to it.
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
Jim W
Year and Trim: 1997 Oldsmobile Aurora
2008 Buick Enclave CXL
Re: project 40th
Post by Jim W »
Based on your purchase price, I would make the effort to fix and sell, even if its goes for $1000 or $1200. Had you paid over $800, its a part out.
Good luck man!
04 Pontiac Grand Prix GTP CompG
Blown93SSEi
Year and Trim: Dark Green 1997 SSEi
Re: project 40th
Post by Blown93SSEi »
I would say fix and sell it. But I'd be biased :)
If you honestly think you can make a profit by flippin it. Do it. If not, Can I have the Driver side headlight?
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
zuper8
Year and Trim: 96 SSEi- 157K
Re: project 40th
Post by zuper8 »
i lean to fixing it all the way up until i see the mileage... i'm just worried it's going to be really hard to sell with 218K or whatever.
- Rachael
Re: project 40th
Hooked up my scanner this morning and pulled the codes.
I was surprised to only find 2.
P0121 - Throttle Position Sensor/Switch A Circuit Range/Performance Problem
P1645 - EVAP Solenoid Output Circuit
Watching the TPS % & voltage on my scanner, it was all over the place. I'm gonna try swapping TPS's again. They said they replaced it, but it doesn't look new to me.
I also found a broken "U fitting" on the EVAP line, so that explains that code.
Still not making any boost, even after swapping BCS's. Hmmmm...
J Wikoff
Year and Trim: 1992 SSE
Re: project 40th
Post by J Wikoff »
Did you look at the BCA? They've failed before.
Re: project 40th
Ha! Car is running great now.
I replaced the TPS with a spare, and it instantly changed the way the car drives. It accelerates smoothly and the trans shifts perfectly, and at the right time.
I still wasn't getting any boost, so I changed the BCS from my 00 just to be sure. No change. I was sure the BCA was working correctly because it was moving the plunger at the correct time. Then I started looking at the MAP sensors. One of the vacuum lines was disconnected. I put it back together and I instantly had boost!
However, found a couple more issues. Its doing that same "grinding, moaning, growling, etc..." that my 95, nates 95, the Grizz, etc, have all experienced. Its pretty bad. I'm assuming I'm going to be changing some motor mounts. Ed, shop still available?
Also, I found a coolant puddle on the floor. Can't see where it came from. Both the radiator and overflow are full, so I'm not sure whats going on there.
Peterg22000
1992 SSEi
Re: project 40th
Post by Peterg22000 »
how big of a puddle? sounds like the heater core.. :S
2009 Phantom Metallic G8 GTS
Appearance; Custom Engine Cover | HSV GTS Spoiler | GXP Front bumper | GXP rear diffuser | HSV GTS Triple Gauges with Dash/Console conversion(First in North America) | HSV GTS Sport Steering Wheel | 20% tint | Holden 6.0 Litre V8 Badges | VE Chrome Lugnut Caps | Blacked out Window & Grill Chrome | V6 door handles | Tinted Tails/Front Side Markers
Performance; Roto Fab CAI | SLP PowerFlow axlebacks | X-Pipe(mid muffler/resignator delete)
Handling; XA Coilovers
12.9199 @ 106mph
1992 SSEi
Re: project 40th
Pretty big, 8" diameter. Looks like it was coming from where the radiator drain plug would be. I'm glad its not the heater core ;)
Peterg22000
1992 SSEi
Re: project 40th
oh, I thought you mean floor of the car.. next time say ground :P
12.9199 @ 106mph
1992 SSEi
Re: project 40th
Oh, my bad. In the garage its the floor, outside its the ground. Today I'm in the garage ;)
Peterg22000
1992 SSEi
Re: project 40th
thats what I figured after you corrected me, but still, you had me for a sec :P
12.9199 @ 106mph
1992 SSEi
nicklikesmilk
Year and Trim: 98 Oldsmobile Intrigue
Re: project 40th
Post by nicklikesmilk »
well if you got it running right, maybe fix it up more. i voted to part it, because it looks like too many problems. maybe not for you, cuz you do this a lot, but i'd part it if it were mine
1993 Park Avenue
200k, well-optioned, and running strong
Re: project 40th
I think it is worth salvaging. We are talking about Haro here. If he does one of his magical cleanings like he does and gets a discount on the welding of the trunk and the rocker, he can easily put a few bucks in his pocket.
BonneMe
Re: project 40th
Post by BonneMe »
Even if you repaired the metal like you plan to, based on the mileage, and the body alone I wouldn't pay more than $1500 for it.
