Antennae not going up and down? Heres how to do a simple fix. This was done on a 93 Buick Lesabre (friends car.)
Most are the same.
Step 1.
Dismount antennae mast. (Sorry no pic. Too easy.)
Step 2.
Take off all the metal clips and screw holding together the thing. There are some type of rivet. Punch those off.
Step 3.
Take the motor apart. Heres what it should look like:
Step 4.
Most likely, the sturdy yet fragile plastic covered metal wire is the culprit in this situation. Take a look.
Either you do like me and melt the thing, or go buy a new for probably 50 bucks. Cheap is good. Free is better.
I melted the thing together like so.
Step 5.
Next take a simple razor blade and cut off the huge boulders (especially if you dont know how to melt together plastic.) Make sure its somewhat smooth. Dont shave off too much or it will be too fragile and crack in the gear.
Step 6.
Your mast should look like this:
Step 7.
Here is the gear. Make sure your cable winds freely in and out of the gear. That is vital.
Step 8.
Alright, great. Now put it all back together and you're back to wonderful antennae automation!
