Page 1 of 2
Felling doggish,,,
Posted: Wed Mar 04, 2009 9:23 pm
by fleettech2252004
Evening to all
Could anyone answer this question?
When i give the car fairly heavy throttle, from a light, it seems to be sluggish until i lightly let off the throttle, then it picks up like an ape on fire,, lol.
Does anyone have this symptom, and can point me to fix this, or am i alone?
Thanks to all in this great club!
Have a great one!!
Re: Felling doggish,,,
Posted: Wed Mar 04, 2009 9:34 pm
by gonzo4191
how long since your last tune up? (plugs, wires, fuel filter etc)
Posted: Wed Mar 04, 2009 9:36 pm
by trf_ssei
need more info, when was the last tune up, engine light (on or off) ect..
Posted: Wed Mar 04, 2009 9:37 pm
by trf_ssei
sorry asked similar question as gonzo
trf_ssei wrote:need more info, when was the last tune up, engine light (on or off) ect..
Posted: Wed Mar 04, 2009 10:24 pm
by gonzo4191
trf_ssei wrote:sorry asked similar question as gonzo
no problem, i'm just a tad bit faster... anywho now we wait for the answer
Posted: Wed Mar 04, 2009 11:19 pm
by LeSabre in Buffalo
Massive KR is what this person is experiencing. Needs a tuneup and better gas.
Also, has the PCM been replaced recently? Could need a CASE learn.
Posted: Wed Mar 04, 2009 11:42 pm
by trf_ssei
i was thinkin maybe a TPS thats why i asked about the engine light.. i didn't even think about KR..
Posted: Thu Mar 05, 2009 5:00 pm
by fleettech2252004
I bought the car last Feb, w/ 169000, I now have 176000, and have done the following,
uim/lim gaskets
head gaskets
major tune up,, w/
autolite xp606 plugs,, OE premium wires, (with loom around each wire), fuel filter, air filter, oil filter and oil every 3000 miles, and seafoam every third tank.
alt. sensing wire (recent,, did it before and after)
maf cleaning
I've tried running with the fpr not on vacume to see if that might help,,, no change there.
I'm stumped,, any ideas?
Thanks
Posted: Thu Mar 05, 2009 5:04 pm
by fleettech2252004
Oh I'm sorry,,, there is no CEL,,, and no codes,, other than P1565, for the cruise control servo position.
besides this little problem it runs great!!
averaging 18mpg city and 28mpg highway
Thanks
Posted: Thu Mar 05, 2009 5:27 pm
by GoldenBullet
Could be a clogged catalytic converter. Is that original, do you know? Also do you know the
History of the O2 sensor?
Posted: Thu Mar 05, 2009 5:34 pm
Oh, it's a 95. Do the 95's have the OBDII or they still OBD 1.5?
Try changing the transmission filter and fluid. Maybe a DIY shift kit.
I'm still betting it's KR.
This happens every time you're giving it heavy throttle from a stop, or only intermittently?
Posted: Thu Mar 05, 2009 6:56 pm
by fleettech2252004
I was wondering about the cat. i'm sure it is original.
The o2 was changed about a month ago.
Yes, it does have the obd 1.5 but has the plug for obd2
Tomorrow i'll drive home from work with the scanner hooked up to see if there is any kr. it should read 0 correct?
I also have ohmed the coils,,,
primary,, #1,4= 0.8,,, #2,5= 1.2,,, #3,6= 0.82
secondary,, #1,4= 5.6,,, #2,5= 4.8,,, #3,6= 5.8
cant tell you if they are original, cant read the numbers on 2,5 but the numbers for 1,4,,3,6 are there.
What do ya think?
Thanks
Posted: Thu Mar 05, 2009 7:06 pm
by harofreak00
I think you should replace the 2/5 coil. Those readings are not within spec.
Posted: Thu Mar 05, 2009 9:20 pm
by RJolly87
harofreak00 wrote:I think you should replace the 2/5 coil. Those readings are not within spec.
Agreed. Also my dad had an issue like this in his Taurus SHO, but it ended up being a bad MAF sensor. It was setting a code stating that the MAF and TPS readings were inconsistent. I understand you cleaned the MAF, and the Taurus SHO is a completely differant animal, so do what you will. The other suggestions are sound also.
Posted: Fri Mar 06, 2009 12:06 am
by 93RedSled-SSE
fleettech2252004 wrote:I was wondering about the cat. i'm sure it is original.
Usually a bad coil will cause a miss, especially noticeable at idle. But, an easy way to "dynamically" test your coils is, with engine running, pull the first wire off and watch to see that the spark jumps from the electrode back to the body of the coil. To avoid being "tingled," shut it off and put the wire back on. Start it back up and repeat for each of the wires.
A good, strong coil should arc back to its body from the electrode. If it doesn't arc back, you have a problem with that coil. A bad coil may arc off one electrode and not the other.
My experience with a plugged cat is that it runs like you pinched the exhaust pipe flat. It will definitely lose power at highway speeds when you need a lot of flow. If it is badly plugged it will kill your mpg too.
It sounds like a MAF, especially if it has a dead spot when you stab the throttle hard. I am assuming you eyeballed it when you cleaned it to be sure both of the little wire like items were in place (?). It's best to use the cleaner that is especially made for cleaning MAFs. Bad news is that MAFs are little pricey for "experimenting" with.
Posted: Fri Mar 06, 2009 12:28 am
by RJolly87
?You can check the maf in this case by unplugging it and see how the car behaves. That is how we nailed it in the SHO.
Posted: Sat Mar 07, 2009 1:50 pm
by trf_ssei
will it even run with the MAF unpluged or does it just become reliant on the TPS
Posted: Sat Mar 07, 2009 3:04 pm
by RJolly87
It typically relies on the tps when the MAF is unplugged, and sets the SES light. Usually guesses what it thinks it should be and goes from that. If the MAF is fine, it will run worse, if it is having problems, usually it will run better, but not great.
Posted: Sat Mar 07, 2009 3:23 pm
It uses a VE tune w/o the MAF. Basically VE is that the computer knows what the engine needs for air and fuel at X RPM, and uses what it's compiled from the MAF to make a guess. It will run w/o a MAF sensor, but not at it's peak.
Posted: Sat Mar 07, 2009 4:22 pm
by fleettech2252004
Hey guys,,
I replaced the 2,5 coil and it does seem to be better.
However, stabbing the throttle to the floor from a dead stop, it still seems sluggish until about 30mph or so.
Hooked autoXray 6000 scanner to it while i drove around, maf,tps,iat, iac and o2 looks good, however, i did have kr of 1 on most of the runs, and i did have kr of 2 on one of the runs.
Also, i noticed that my spark advance was 14.7 at idle and when i took off, it read like 8 or so and then came back up to 12 aqnd slowly settled around 10.6 or so.
Does it possibly sound like stretched timing chain?
Thanks for all the help!!!
