80's firebird running hot
Posted: Sun Feb 08, 2009 10:26 pm
by swampthing
ok so i have another friend with a broken car! she is 16 and just got her first car... a 1988 firebird ugh! it is gonna be a headache i can tell. so anyways the car has a new radiator, thermostat, coolant temp sensor and supposedly a new water pump. it is still running hot like almost to the redline like 250 degrees or so. the fan seems to be coming on sometimes and not other times what direction should she take with this?
Re: 80's firebird running hot
Posted: Sun Feb 08, 2009 10:39 pm
um, 150 degrees isn't hot at all. You mean 250 degrees?
Posted: Sun Feb 08, 2009 10:41 pm
by GoldenBullet
what engine does it have?
Posted: Sun Feb 08, 2009 10:44 pm
by swampthing
yeah 250 not 150 that was a typo.
it has the 2.8 v6
Posted: Sun Feb 08, 2009 10:46 pm
Um, could be a blockage in a coolant passage. Try a full system flush, with a flush product, and see if that helps. Also, try burping the system with the t-stat out.
Posted: Mon Feb 09, 2009 1:13 am
by swampthing
i'm kinda wondering more about the wiring issues that i know were common with this Gen F-body
Posted: Wed Feb 18, 2009 10:52 pm
by SCD88GA
These cars are common for having plugged catalytic converters, that will make it run hot! Another possibility is a faulty mass airflow sensor causing it to run lean making it hot! Make sure the fan is spinning in the proper direction as well. Check it out and keep us posted!
Posted: Wed Feb 18, 2009 11:24 pm
by gonzo4191
off topic, where have you been grandam man??!!
Posted: Wed Feb 18, 2009 11:34 pm
by swampthing
well I talked to her and they installed a new fan motor and an aftermarket wire harness and it seems to have fixed it for now as soon as it gets up to temp the fan comes on and it even runs after you shut it off for about 30 seconds
Posted: Tue Feb 24, 2009 2:57 am
by BonneMe
3rd gen's have to scoop up air from below due to the nose design, and if they don't have the proper deflectors underneath, things get hot fast.
Posted: Tue Feb 24, 2009 8:55 am
by swampthing
well the running hot seems to have been fixed, but today i foundout it stalls while braking sometimes i was thinking vacuum leak, any thoughts?
