girls 92 sse
Posted: Wed Jan 14, 2009 10:06 pm
by gonzo4191
this girl i know had been having troubles with her sse. its a 92 sse non s/c. it has troubling starting and just today, it stalled out in the middle of an intersection. the check engine light IS ON, but i have yet to jump the pins. although her dad says it has to do with the faulty MAF that he unplugged to get it running? coudl that be cuasing all the problems? where should i look first?
Re: girls 92 sse
Posted: Thu Jan 15, 2009 7:02 am
by sTonedefone
try cleaning the maf w/throttle body cleaner the install get car started and check voltage, less than .5v on gnd, 5v reference, and between .5v closed throttle - 4.5v wot w/eng running, also has the fuel filter ever been changed? do voltage checks w/dmm or computer safe power probe
Re: girls 92 sse
Posted: Fri Jan 16, 2009 9:04 pm
by PontiacSE93
I own a 1992 Pontiac Bonneville Se with 186,000 miles on it and i have never had any problem since i got it at 174,054 miles. and this is my second bonneville and my first was 1993 pontiac bonneville se and the only problem i had when it hit 191,000 miles on it because the rpm started to act up on me.
Re: girls 92 sse
Posted: Fri Jan 16, 2009 10:11 pm
by 93RedSled-SSE
gonzo4191 wrote:...the check engine light IS ON, but i have yet to jump the pins.... where should i look first?
1st step... Get the code(s), since it will probably lead you/us in the right direction. Otherwise, you can waste a lot of time, guessing. #-o
