It has been a while since I have been on the bonneville forum but I am back. My soon to be ex thinks the car has major problems and just wants to give it back to me! I took it into the shop to have them find out what is wrong. I know the fuel level sensor is bad. The shop told me that there was a problem with the EGR valve. I replaced the LIM gasket a few years ago and had to put a new pipe (?) on because the other one cracked. Could I have missed something there? The mechanic told me that the EGR valve could just be causing ALL the other problems. On top of the fuel level sensor, this could be my only real problem!! Could I be so lucky as to have to just replace that?! He also tested the coils and they checked out ok. The plugs and wires are all "new". Below is the printout from the computer. Thanks for the help!!!
Also, if it is the EGR valve.....how exactly can you tell? I have cleaned it and everything. There doesnt seem to be anything sticking. Could I have messed it up at one point by messing with the screw on the bottom??
I replaced that "pipe" just below the EGR valve. Its metal. I have sprayed a TON of carb cleaner everywhere to find a vacuum leak and couldnt find anything! The screw underneath the EGR valve looks like a torx bit screw. I dont remember if I did anything with it last year. If I did, Im assuming I screwed it up!
