Page 1 of 2
Motor mount mod: DONE!
Posted: Mon Sep 29, 2008 7:17 pm
by bonnevillain
EDIT: scroll down for final product
it works for now, but the bolt was BARELY long enough, and it needs something in there to dampen the vibration. where would be the best place to put something to dampen it? and what easy/cheap material would you suggest? i thought about part of a motorcycle inner tube.. i have a few laying around. would that be stiff enough? also... How much should i crank down on it? the washers are compressing the top hockey puck a bit.
Next up:
and, the previous mod: note the lack of rust :banana:
Re: My latest project...
Posted: Mon Sep 29, 2008 7:31 pm
by SSEimatt93
All I have to add is that your under carraige looks awesome! Very Clean.
I'm not really sure how a ported L36 Manifold should look, so I'm not much on that one.
Same with the hockey puck mount, however, it looks pretty solid, I would imagine you will get some wikid steering wheel vibrations though?
Posted: Mon Sep 29, 2008 7:33 pm
by TenGHz
Let me know how that LIM Porting goes. I have a new LIM and you telling me how much improvement it gives your car will get me moving on getting mine done. :lol:
Re: My latest mod.. question
Posted: Mon Sep 29, 2008 7:37 pm
by bonnevillain
I am following bill's advice and going with the LIM / FWI / Cat combo... so my results may vary a bit from yours, but i will let you know for sure.
Posted: Mon Sep 29, 2008 7:39 pm
by TenGHz
Well, I already have the FWI, just no new kitty. So, shouldn't be TOO far off.
Posted: Mon Sep 29, 2008 8:02 pm
by 1337ssei
adding some of those energy suspension endlink bushing might dampen it
Posted: Mon Sep 29, 2008 8:07 pm
by 01bonneSC
To dampen solid mount vibes you need to put a rubber/neoprene/durable-flexable-material between the washer and the frame under the car.
Posted: Mon Sep 29, 2008 8:08 pm
by bonnevillain
there was / is no washer under the car. There wasn't one when i took it off, so there isn't one on there now.
Posted: Fri Oct 03, 2008 6:04 pm
by bonnevillain
I tried some 80 cent rubber washers underneath there, and it helped, but the vibration was still there. I think they were too soft. My mount is now using a marshmellow spring by Firestone. These are specifically designed to dampen vibration on the heavy machinery at my dad's work. They replace conventional springs in a lot of these machines, and it works much better now. there is only a hint of vibration at low throttle in 2nd gear (about 30mph) but not enough to bother me. i have an old crusty endlink between the bolt and frame on the bottom, and it helped, but im sure a new one would work even better. I could also put one on the top as i have plenty of bolt left, but i will leave it for now.
http://www.airsprings.com.au/Marshmellow.cfm
here's mine: almost the exact same size as 3 hockey pucks
Posted: Mon Oct 06, 2008 12:18 am
bonnevillain wrote:I tried some 80 cent rubber washers underneath there, and it helped, but the vibration was still there. I think they were too soft. My mount is now using a marshmellow spring by Firestone. These are specifically designed to dampen vibration on the heavy machinery at my dad's work. They replace conventional springs in a lot of these machines, and it works much better now. there is only a hint of vibration at low throttle in 2nd gear (about 30mph) but not enough to bother me. i have an old crusty endlink between the bolt and frame on the bottom, and it helped, but im sure a new one would work even better. I could also put one on the top as i have plenty of bolt left, but i will leave it for now.
Can you get more of those? If/when i get another SSEi i would like one.
Re: Motor mount mod: DONE!
Posted: Mon Oct 06, 2008 12:28 am
by bonnevillain
not on a mass scale, but shoot me a PM when you're interested. He could probably scrounge up 1 or 2 more
Posted: Mon Oct 06, 2008 1:52 pm
by Allmachtige
Not bad, looks good.
Posted: Mon Oct 06, 2008 4:51 pm
by bonnevillain
final product:
Don't mind the second lock nut, i Hadn't tightened it down yet
Posted: Mon Oct 06, 2008 5:00 pm
by bruce
that looks nice! After driving mine for a month or so i forgot about the vibration...My girlfriend doesn't even notice anymore!
Posted: Mon Oct 06, 2008 6:00 pm
by TenGHz
bruce wrote:that looks nice! After driving mine for a month or so i forgot about the vibration...My girlfriend doesn't even notice anymore!
I think there's a joke here, but I'm gonna leave it alone. :bow:
Looks really good, Ryan. How's the LIM porting coming along?
Posted: Mon Oct 06, 2008 10:52 pm
by bonnevillain
It's done. i just have no time to install it.
Posted: Mon Oct 06, 2008 10:53 pm
by WhiteArrow3800
LMAO, I may quote that! :laughing3:
Anyway, looks good. I wish I had just gone against my mom's urge to put the stock front trans mount in. She paid for it, but at the time If I had known the rear trans mount was bad as well, I would have had her pay for the rear mount and I'd have made the solid front mount anyway... :roll:
Let us know what the difference is :twisted:
Posted: Mon Oct 06, 2008 10:57 pm
by bonnevillain
it's.. well... solid. it cost $5, and gives you some better launching abilities for sure. At the expense of a little vibration.
Posted: Tue Oct 07, 2008 12:28 am
by Boostershot
bonnevillain wrote:it's.. well... solid. it cost $5, and gives you some better launching abilities for sure. At the expense of a little vibration.
Any chance on a part number for that baby? It looks ideal for an aftermarket mount
Posted: Tue Oct 07, 2008 12:33 am
by bonnevillain
I can get it for you tomorrow
