Need help finding a amp
Posted: Sun Sep 21, 2008 10:13 pm
by calaeb0896
Well i got this sub for a real good deal from my boss for about 100 bucks and i need to find a decent amp to push it. I see crunch amps and what not ive been think about it just for now so can someone find me a cheap amp for under 150 heres the specs on the sub.
http://www.decibelgarden.com/ELEVATION-EXSPECS.html
im getting the execution sub the 15 inch one
Re: Need help finding a amp
Posted: Sun Sep 21, 2008 10:28 pm
by its840
so your buying a 400$ sub but yet your looking for a 100$ amp??? that realy doesnt make much sense...
Posted: Sun Sep 21, 2008 10:37 pm
by bonnevillain
x2. the amp is very important...
check your local craigslist for a mono amp with as many watts as possible.
Posted: Sun Sep 21, 2008 11:00 pm
by calaeb0896
no i said i got it for a deal it was extra money that i had so i bought it. So now money for the amp has to come out of my savings so i want to use as little as i can until i get a better job. So i should be looking for a mono amp?
Posted: Sun Sep 21, 2008 11:02 pm
by bonnevillain
unless you want to amplify other speakers, yes. That's all you need, and they are generally cheapest.
Posted: Sun Sep 21, 2008 11:12 pm
by calaeb0896
ok im thinking that i will spend about 150 or less any ideas?
Posted: Mon Sep 22, 2008 8:53 am
by Red Rocket
calaeb0896 wrote:ok im thinking that i will spend about 150 or less any ideas?
I'm sorry but you're not going to find an amp to power that sub with a budget of $150. You're looking at a minimum of $250 even if you buy used. Don't go cheap on the amp.
Posted: Mon Sep 22, 2008 12:02 pm
by grandprix104
With a quick search on ebay, i found you can get a new HiFonics amp for around $200 that will push it ok. If you get a used one it would be cheaper. Check out your local pawn shops too. You need something that pushes 1500 RMS. do not look at max power ratings.
Posted: Mon Sep 22, 2008 2:02 pm
by calaeb0896
ok thanks alot for the help guys
