Anyone can point me where to start trouble shooting? No turn signals, indicator light/arrors or sound and no external signals when turning the turn signal stalk. Headlights and parking lights work. Reverse lights work. One brake light on driver's side is out, passenger side brake light works. Would the flasher be under the dash by the fuses? I assume it would be a round pot? There's also some black plastic module hanging down under the dash (I'll take pictures in a while). Thing is that the inside dome lamps worked at one time and now they're not working either, even when working the door switch manually. So to sum up: Driver side brake light, interior dome lights, turn signal arrows on dash and external turn signals don't work.
Thanks
W
No turn signals/dome lights on 1960 Bonneville
PatrickGCrump
- LE Member
- Year and Trim: 1960 Pointiac Bonneville Vista Sedan
