1991 SSE engine Problems
Posted: Sun Jul 20, 2025 4:19 pm
Moin, Moin,
Unfortunately, I'm having problems with my Bonnie, again. I have no experience with the 3.8L engine, and in Germany, there's no repair shop that's familiar with them.
When the engine is cold, it runs well, with all cylinders.
When the engine warms up, it sputters, and it is running on 5 and 4 cylinders
At high revs, the engine running again on all 6 (over 3000rpm).
If I unplug the injector connector when it's running rough,
I can locate the cylinders that aren't running.
I've swapped the injectors, and they're not the problem.
I suspect broken wires. (I've already located and repaired some in the past.)
I'd really like to replace the wiring harness on the engine, as it's been tampered with.
Unfortunately, it's not available as a spare part. At least not from the usual sources.
Does anyone have any other ideas? Or a source for a wiring harness?
Spark plugs are new.
Ignition wires are new.
I have sparks in every cylinder.
compression is finde too
Regards Mike
Regards Mike
