2001 SE Transmission Issue
Posted: Mon May 15, 2023 11:34 am
by 57j2olds
Hello,
2001 Bonneville SE.
At 112K miles I had the trans rebuilt.
I'm at 214K miles now and I feel it slipping when I'm in high gear when I want to accelerate.
Nothing from a standstill.....only in high when, for example entering freeway...cruise set and creeping up a hill etc.
I just put 3 new coils and an ignition control module in thinking it was a miss-fire.
Is there anything I can do other than a full teardown?
Re: 2001 SE Transmission Issue
Posted: Tue May 16, 2023 6:18 am
by nos4blood70
Is it slipping or do you have erratic RPMs going up and down and bucking a little bit?
Posted: Tue May 16, 2023 8:35 am
by 57j2olds
I guess more like bucking.....
Posted: Wed May 17, 2023 8:29 am
by 57j2olds
nos4blood70 wrote:Is it slipping or do you have erratic RPMs going up and down and bucking a little bit?
So yes..it's bucking and the RPM's are erratic.
What are your thoughts?
Thanks
Posted: Wed May 17, 2023 9:24 am
by harofreak00
99% of the time, your symptoms are ignition issues under load. I know you've replaced the coil and ICM already. Do you have a way to watch live data with a scan-tool to determine which cylinder is misfiring? It wouldn't hurt to change the plugs and wires also.
Posted: Wed May 17, 2023 11:01 am
by nos4blood70
I would change plugs and wires as stated above. I've also had a dirty MAF cause similar situations.
Posted: Wed May 17, 2023 2:04 pm
by 57j2olds
Regarding dirty MAF......I assume there is a special cleaner for this.
Can I spray it on the vehicle or do I need to remove it?
Thanks
Posted: Wed May 17, 2023 2:18 pm
by Sirius
Yes, there is a special MAF cleaner and, yes, it's kinda pricey. I think it might be easier to clean with the MAF removed.
Posted: Thu May 25, 2023 9:44 pm
by nos4blood70
You can get the MAF cleaner at any auto parts store. Remove the MAF and spray it down.
Posted: Tue May 30, 2023 2:28 pm
by 57j2olds
It was my plug wires!
Or my MAF...I cleaned it to.
Thanks for your help as always....
