Running RCAs from hu to amp in trunk 2000 bonneville ssei
WV30258
Post by WV30258 »
We are putting an aftermarket hu and amps in our bonny and can't figure out how to run the rca plugs from the hu to the amp we're putting in the trunk. Could someone give us some ideas, preferably with pics? Thanks.
Re: Running RCAs from hu to amp in trunk 2000 bonneville sse
I have no pics, but mine run under from the head unit, under the shifter and cup holder, under the carpet for the exhaust tunnel in the second row, and then under seat bottom cushion, stuffed through to the trunk.
GothicPontiac
Year and Trim: 1984 Bonneville, base model.
Post by GothicPontiac »
If you want to do it right, run them near the floor.
Not sure how the 2000s Bonnevilles are, but in the 80s ones you unscrew the door sill plate, and run the cables along there.
"What the f*** is the point of driving, if the ride doesn't reflect the person behind the wheel?"
