Master cylinder. .. 99' Bonneville
Posted: Sat Jul 28, 2018 7:43 pm
by wpbrink
Has anyone replaced the master cylinder? If you have could you offer some advice on what to do or pictures?
Re: Master cylinder. .. 99' Bonneville
Posted: Mon Jul 30, 2018 10:48 am
by 96 SSEi
what is the issue with the master?
Posted: Mon Jul 30, 2018 10:56 am
by wpbrink
Leaking
Posted: Tue Jul 31, 2018 7:45 am
by wpbrink
The master cylinder is leaking and I will be replacing it shortly.... Brake pedal goes to the ground. Do I need to bleed the ABS system also and if so I have no idea what to do. ..
Posted: Tue Jul 31, 2018 10:36 am
by 95naSTA
I replaced all of my lines without doing any special ABS bleeding procedures.
Posted: Tue Jul 31, 2018 12:31 pm
by wpbrink
Do you bleed the system with the car running or just keyed on?
Posted: Tue Jul 31, 2018 2:25 pm
by 95naSTA
I just gravity bled it, then did a 2 person bleed by pumping the brakes. I don't even remember having to turn the car on.
You're supposed to bench bleed the master before you install but I didn't do that either.
