building up my 3800 for more power
Posted: Sun Feb 25, 2018 11:27 am
by soundman9826
so yesterday i went to a friends shop and we talked about what i wanted to do to my 95 bonneville, engine wise. we talked about putting a northstar in it but eventually decided on building up the 3800 instead. we figured that it would be cheaper and easier to build up the 3800 instead of trying to make a northstar v8 fit. so first thing we are going to do is get a rebuild kit and arp head studs for it so its ready to make more power/take boost. we are also looking into putting the series 3 aluminum intake on it to replace the plastic one. i dont think its to hard to put a series 3 aluminum intake on it but ill have to do some more research about it. it is a 1995 so i am thinking i will ether have to see if i can get a obd2 pcm from a 1996 bonneville to work or get an after market ecu and tcm.
Re: building up my 3800 for more power
Posted: Sun Feb 25, 2018 1:22 pm
by 95naSTA
Your 4t60-e trans wont take the power.
Get a L67 drop out with pcm and 4t65-hd trans.
Posted: Sun Feb 25, 2018 1:27 pm
by soundman9826
yeah we also brefly talked about getting a "built trans"
Posted: Sun Feb 25, 2018 3:06 pm
by 95naSTA
A built 60e won’t last. Start with a 65-hd.
Posted: Sun Feb 25, 2018 11:31 pm
by MattStrike
+1 on an entire series 2 L67 motor/trans/pcm dropout. Make sure you plan your build accordingly, and build the trans for your hp goal.
Posted: Mon Feb 26, 2018 5:52 pm
by nos4blood70
If you're going to keep the car NA, you won't be making all that much power without valve train mods... and even then....
The L26 intake swap isn't really worth it. It offers no performance benefits.
Posted: Mon Feb 26, 2018 6:12 pm
by soundman9826
i thought i said it but i guess not. i do plan on putting a turbo on it eventually.
