I own a 1994 ssei and I did the pre pulley replacment tune up that willwren recomended.
I ordered a 2.5 inch from pulley boys
Now I need to know how to get the old pulley off?
Also do I need an oversized idler pulley?
how do I get my s/c pulley off?
streetfreak
- SE Member
- Year and Trim: 1994 Bonneville SSEI
Red 94 SSEI
Ultra Boost
- Year and Trim: 1994 Buick Park Avenue Ultra
Re: how do I get my s/c pulley off?
The M62 pulley is keyed. It should pretty much tap off. I had to use a 3 jaw puller, but it came off easily.
Needs more blower whine!
- willwren
- Retired Admin
- Year and Trim: .
You will not be able to tap it off. You need a 3-jaw puller. You'll also need an old belt and some large channel-lock or vice-grip pliers to hold the pulley in order to remove and replace the nut unless you have air tools.
WARNING: The 3-jaw puller is ONLY for 91-95 L67's. 96 and newer L67's need a special puller that fully supports the back of the pulley.
Then use the 3-jaw puller. Depending on what tools you have, you may find it easier to move the coolant overflow bottle out of the way.
Moving to Forced Induction.
streetfreak
- SE Member
thanks!
uhhg I know I have a 3 jaw pully now I just gotta find the stupide think lol
So I shouldn't need an over sized idler pulley?
Red 94 SSEI
- willwren
- Retired Admin
- Year and Trim: .
Techinfo. Link at the top and bottom of the page:
http://www.pontiacbonnevilleclub.com/fo ... =44&t=1669
Keep in mind, I have wildly different setups on each car, and I wrote that article some time ago. I run a 3.25" on my accessory tensioner because I run a smaller alternator pulley (custom 160 amp alternator). I can't run an oversized idler on that same car for the supercharger belt, as my WP pulley is larger by 10%. So I ADDED another bracket and fixed idler which I use only when running the 2.2" and 2.0"
However, I run a larger idler on my 95 with a 2.5" supercharger pulley.
This gives proper belt tension and better belt wrap to prevent belt slipping. In simpler words, what I usually tell people is that when 'pulleying' down a series 1 L67, the idler is REQUIRED (or a short belt) on the 91-93 L67's, and optional but highly reccommended on the 94/95 L67.
I assume you already read this:
http://www.pontiacbonnevilleclub.com/fo ... 468#p14468
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
streetfreak, if you havent, please do read that article. BEFORE you pulley drop. KR is very bad.willwren wrote:I assume you already read this:
yourgrandma wrote:High
streetfreak
- SE Member
Like the Bible! I read it many times and printed it out and brought it with me to my mechanic so he could make sure everything was checked out.
Oh and thank you guys for u'r help u'r all awesome
Red 94 SSEI
