Market Info Wanted: # of GM Cars that Have Rotted Subframes
Posted: Tue Sep 12, 2017 3:43 pm
Hello, I need market information. Specifically, the number of EXISTING GM Cars that have Rotted Subframe Bushing Holes, and whose owners would like a Low-Cost Solution.
Background:
I replaced my 97 Pontiac Bonneville SLE's subframe that had rotted #2 and #3 subframe bushings and subframe holes. I went through the pain of doing this in order to pass all necessary safety inspections in my state,
I'd like to determine whether it would make sense for me to develop a solution to help the typical DIY mechanic (like myself), who has the same problem but wants a solution but doesn't want to replace their subframe.
It seems that it would cost a typical non-DIY owner about $1000 to replace a rotted subframe and 4 bushings (#2 & #3) because the cost of a good used subframe is $300, 4 bushing kits is $200, and professional labor is about $500). Also, rotted subframes & bushings are a safety problem caused by faulty GM designs, and therefore replacement should be performed at no cost by having GM RECALL all cars having this problem. However, this is not the case, so it's now up to typical owners to pay the full cost of repair, or DIY mechanics to find a low-cost solution to their problem.
I have an idea for such a solution that I may be willing to develop, depending on its demand, which could cost a DIY mechanic only about $500 to only replace 4 bushings (#2 & #3), add a few more parts easily, and NOT NEED TO REPLACE OR EVEN REMOVE THE ENTIRE ROTTED SUBFRAME! My solution would fix this problem enough to pass a state safety inspection.
MY QUESTION IS:
1) How many GM cars exist in the USA, over all years and all makes and models, have a rotting subframe/bushing problem, (i.e. just enough subframe/bushing rot for one, some or all of the #2 and #3 bushings to pop though their subframe)? These cars should be well enough to last for a few more years, at least, if their subframe problem is repaired. Note that there should be no body rust/rot problems above the subframe bushings.
Thank you in advance for your answers. Please remember that I'm looking for market research information, on numbers of vehicles with this problem, and not an alternate solution or your experience with this issue. Just numbers please!
I'll be checking this forum, from time-to-time, while I start by taking some subframe measurements and spend an hour or two to make preliminary drawings of my design idea.
Thanks again!
Background:
MY QUESTION IS:
Thanks again!
