Driver information center doesn't work properly
Posted: Tue Aug 08, 2017 5:41 pm
by cinzy0
Hi@everyone
I got a problem with my DIC, just like this http://www.pontiacbonnevilleclub.com/fo ... 34330.html
50/50:Sometimes it works fine. OR during systems check it flashes and then turns off and again 50/50 DIC starts to work after 5-10 mins
Compass and everything else in the cluster always work fine
I didn't check fuses because it's night already
Any suggestions?
Re: Driver information center doesn't work properly
Posted: Tue Aug 08, 2017 8:56 pm
by 96 SSEi
you may want to remove the dic and check the connection in rear
Posted: Wed Aug 09, 2017 2:12 pm
by jonnevilleSSEi
I had the same issues in my 97. Was never able to fully resolve it after 5 times removing the dashboard and instrument cluster to clean and manage the pins. If you're ready to try that I have the process documented somewhere on this forum, in detail with photos and things I had to learn the hard way. Let me know if you have any trouble locating my post about that.
What it seems to come down to is both clusters (Compass and DIC) are connected to the computers with a separate bulk wire connector (20+ pins?) I saw mine had a bent pin, not sure from what, nor if that had anything to do with the problems. I noticed when it would flicker off that I could press on the plastic cover (fully assembled) and pressing it towards the front of car (into the dashboard) would illuminate it temporarily, though sometimes it would stay on. I'll look for the article, I hope you are able to fix yours, it used to bug the piss out of me, every time I thought it seemed resolved.... and my heart would feel failure when it shut off again.
http://www.pontiacbonnevilleclub.com/fo ... 46475.html
Posted: Wed Aug 09, 2017 4:01 pm
by cinzy0
Thx a lot
I'll try to look and fix this
Posted: Thu Aug 10, 2017 4:45 am
by cinzy0
I don't want to make another thread
I always got SES light while using brakes or going downhill
And which scanner better to buy for 92 bonne?
Posted: Wed Aug 23, 2017 10:49 am
by cinzy0
Problem solved, thx a lot :) Bad connection.
I hope this doesn't happen again :>
Posted: Wed Aug 23, 2017 2:38 pm
by 96 SSEi
92 WOULD NEED AN obd1 scanner - get a basic one that will pull some real-time data also - the good ones get very pricey
$100 - 200 should get you one that will help you be happy.
