2000 lesabe limited horn stopped blowing when doors are lock
Posted: Fri Mar 10, 2017 11:14 pm
ok all the sudden now my horn doesn't blow when doors are locked with remote,,,lights still flash,,,horn works fine otherwise...ideas ??
The forum for Pontiac Bonneville enthusiasts
http://pontiacbonnevilleclub.com/forum/
http://pontiacbonnevilleclub.com/forum/viewtopic.php?t=50327
Personal Choice Features
The following list of features that are available on your
vehicle can be programmed to each driver’s preference
for each of the key transmitters.
Automatic Door Locks: This feature programs your
door locks to automatically lock or unlock when
shifting in and out of PARK (P).
Security Feedback: This feature provides feedback
to the driver when the vehicle receives a command
from the remote keyless entry transmitter.
yellowblue
2-11
Delayed Locking: This feature lets the driver delay
the actual locking of the vehicle. When all doors
have been closed, the doors will lock automatically
after five seconds.
Perimeter Lighting: When the button with the
unlock symbol on the keyless entry transmitter is
pressed, the Daytime Running Lamps (DRL),
parking lamps and back-up lamps will turn on.
For more detailed information and programming
instructions, refer to the Index for each individual
feature listed above.
Security Feedback
This feature provides feedback to the driver when the
vehicle receives a command from the remote keyless
entry transmitter. Feedback is only provided if all doors
are closed. One of the following modes may be selected
for each transmitter:
Mode 1: No feedback when locking or unlocking
vehicle.
Mode 2: Parking lamps, back-up lamps and the
DRL exterior lamps will flash twice when unlocking the
vehicle and flash once when locking the vehicle.
Mode 3: Horn chirps when all doors are unlocked (second
time the button is pressed) and when locking the vehicle.
Mode 4: Parking lamps, back-up lamps and the
DRL exterior lamps will flash twice each time the
button with the unlock symbol is pressed; the horn
chirps when all doors are unlocked. Parking lamps and
the DRL exterior lamps flash once and the horn chirps
Feedback will be provided according to the mode that
has been selected. The exterior lamps will not flash if
the manual parking lamps are on.
Vehicles are delivered programmed in Mode 4.
To change to another mode:
1. Close all the doors and turn the ignition on.
Keep all doors closed throughout this procedure.
2. Press and hold LOCK on the driver’s power door
lock switch throughout this procedure. All the doors
will lock.
3. Press the trunk button on the transmitter. The
security feedback will remain in its current mode.
4. Press the trunk button again. Each time the trunk
button is pressed, the security feedback will advance
to the next mode, and the horn will chirp.
5. Release the power door lock switch.
yellowblue
2-12
This procedure only changes the mode for the
transmitter used to change this setting. The procedure
will need to be repeated for the second transmitter.
If your vehicle is equipped with the Driver Information
Center (DIC), you must program this feature through the
DIC. See “Driver Information Center” in the Index.
