Battery draining
Posted: Fri Oct 02, 2015 7:55 am
by irish91983
Hi All
Last week I installed my new radio. now my battery keep dying. It tested as a good battery. Has anyone else had this happend to them after an install?
Thanks, Keith
Re: Battery draining
Posted: Fri Oct 02, 2015 9:39 am
by nos4blood70
I'm assuming aftermarket? How did you wire the switched and constant power? Did you make sure you used to proper adapter? I know that some can just leave the radio on at all times.
Posted: Fri Oct 02, 2015 11:20 am
by irish91983
yes aftermarket, I used the GMOS-09 harness. I just matched the colors from what merta and kenwood had listed.
Posted: Fri Oct 02, 2015 11:44 am
by nos4blood70
Does the radio turn off with the key?
Posted: Fri Oct 02, 2015 2:53 pm
by irish91983
yes it does.
Posted: Sat Oct 03, 2015 1:24 pm
by gweg_b
After I upgraded, my battery kept dying. Turned out to be the OnStar module behind the back seat. Don't know why, but Will (SSEiMan01) had the same problem, and he told me to unplug it. I did, and the battery was fine the next day, and has been since (the whole thing is now gone in my car).
Might want to at least try that overnight if you run out of options.
Posted: Sat Oct 03, 2015 4:13 pm
by irish91983
What is the OnStar module?
Posted: Sun Oct 04, 2015 12:34 pm
by irish91983
I found it I just had to open my eyes :)
But I also noticed that once I lock my car with the fob after about a minute or two my alarm goes off then i lock and unlock my car with the fob again and its fine.
Could this be due to the install of the new radio?
Thanks, Keith
