Coolant leak where upper hose meets engine block
Posted: Sun May 31, 2015 9:17 pm
by bonnevilleCyborg
So my upper radiator hose failed catastrophically one day. I fixed it and put a new hose on and the new hose is secured with worm screws. Unfortunately, these worms screws always seem to come slightly undone, and coolant will leak out of them onto the exhaust manifold. What do you all recommend I use? I threw away the original "God's Grip" style clamps because I didn't think I could get them back on.
Re: Coolant leak where upper hose meets engine block
Posted: Sun May 31, 2015 10:23 pm
by FiendScurro
I use the same style. It was a pain but what worked for me was retightening after its all hot like when you get home from store or work.
Posted: Mon Jun 01, 2015 12:10 am
by bonnevilleCyborg
But I've been retightening it, and it always seems to loosen up by 1 or 2 of those slot thingys. I think I'm going to get some of the clamps and see if they work, may have to eat some Gamma Rays and Hulk out to get them on.
Posted: Mon Jun 01, 2015 3:04 pm
by Jfridge92
I've never been able to get the worm clips to stay tight on those hoses, I've always gone back to the oem style clips. They're a pain to get on and off, but they hold things like they should be haha.
Posted: Tue Jun 02, 2015 7:00 am
by FiendScurro
Or even putting a new worm screw clamp on. I replaced when I replaced hose.
Posted: Tue Jun 02, 2015 8:05 am
by JohnR
The pliers for removing and installing the factory style "spring" clamps are fairly cheap and worth the investment.
