air ride pump dead
Posted: Thu Apr 30, 2015 9:26 pm
by monte0
So found another issue I'm guessing is common to this platform, the air ride compressor is dead. I replaced all the lines as they were rotted. Checked for power and found the fuse in the drivers fuse panel labeled "passkey/air ride" was dead all together. I tried to trace it out but without the schematics it's tough. I did try the manual button in the truck for filling tires and their is a relay clicking but the pump isn't switching on, so I'm guessing being under the car it's more then likely seized.
Does anyone have the pinout for the rear pump plugs and where the fuse for te pump feeds from?
Re: air ride pump dead
Posted: Fri May 01, 2015 5:22 am
by MKMike
Best bet, if no one has the pinout, is to pick up a set of factory service manuals off Ebay.
I saw 2 sets there, both around $40 shipped.
Posted: Fri May 01, 2015 9:30 am
by monte0
Yea, if worse comes to worse I might have to.
But today I started with the pump itself and found it was seized solid. So I'm oiling it and trying to free it up some. Does anyone know what lube was used in them or was it an oil bath system? Can't tell cause the casing was washed out by water
Posted: Sat May 02, 2015 11:59 pm
by monte0
Ended up getting the pump running and it "kinda" pumps some. Electric motor is fine just the cylinder is weak, piston is worn
Posted: Mon May 18, 2015 9:54 pm
by monte0
Just a update on this, bought a rebuilt pump and replaced the rear struts and now working great
Posted: Tue May 19, 2015 9:37 pm
by KM AXer
monte0 wrote:Just a update on this, bought a rebuilt pump and replaced the rear struts and now working great
=D>
Posted: Tue May 19, 2015 9:55 pm
by monte0
Only took replacing everything..lol
Posted: Tue May 19, 2015 11:47 pm
by 96 SSEi
hi, this may be of some help to you.............http://www.gmforum.com/howto/1998SM/sus ... ontrol.pdf
O...O... wont let me post a working link- I suspect sabotage...lol
maybe you can copy/paste the link in address bar of your browser?
Posted: Wed May 20, 2015 12:02 am
by MKMike
monte0 wrote:Only took replacing everything..lol
When I bought my 93 SE, that's the way I fixed my AC, since the compressor was missing and the system open for who knows how long.
On the plus side, it is nice and cold on the hottest of days.
Glad you got your system working!
