Rubber vacuum fitting replacement?
Posted: Mon Nov 24, 2014 7:13 pm
by ron350
What is a good replacement for this rubber vacuum fitting?
This is one of the 2 rubber vacuum fittings on the side of the throttle body.
The small end goes over a tube that is .250”OD and the large end goes over a tube that is .400”OD.
Re: Rubber vacuum fitting replacement?
Posted: Tue Feb 10, 2015 1:44 pm
by justhalc
Good luck, I wasn't able to find anything for that or the piece that goes into the middle of the intake plenum on the firewall side.
Posted: Tue Feb 10, 2015 2:07 pm
by J Wikoff
When I've needed something like that, I used two different sizes of vacuum tube. One fit into the other.
Posted: Wed Feb 11, 2015 9:39 pm
by ron350
I was hoping someone made those out of silicone but all I can find is original GM #24504768.
Posted: Thu Feb 12, 2015 5:38 pm
by bonniebird
had the softer rubber end split a little and the hard plastic tubing cracked on me...so far my black electrical tape wrapping abilities have served well for the past year...but it would sure be nice to get a hold of the real replacement....
