What plugs do I need with these mods?
Posted: Sun Oct 19, 2014 5:03 pm
Apologies in advance if this seems like a bit of a noobish question.
The '02 SSEi I just bought has seen some mods from the previous owner. He mentioned that someone who used to work at ZZP did a lot of the work so I'm pretty sure everything's correct. However, I'm going to be replacing the coolant elbows and rocker cover gaskets fairly soon(the car already has aluminum LIM gaskets, score!) and it's probably a safe bet to replace the plugs and wires while I've got everything apart. The problem is that I'm not entirely sure what plugs would be best for what this car has.
Environmentally, I live at high altitude(around 6500ft, with regular trips up to 7500-8000 and occasional runs up past 10,000ft). The highest fuel grade that's available is 91, though less octane is needed due to the altitude. The PO sold his Aeroforce separate from the car, but claimed that KR was just fine with his setup. I plan on getting one after getting typical maintenance and repairs taken care of.
The car has a ZZP ECM tune, 3.5" S/C pulley, fone filter intake(inside the engine bay, though... eigh) a ZZP powerlog, 3.5" downpipe with new cat, and 1.9 roller rockers. I'm assuming this setup needs something a little colder than stock, but by how much?
