Swaying Issue
Posted: Sat Sep 20, 2014 8:57 pm
by gap1533
My 2001 SSEi has developed an issue over the last couple hundred miles. The car tracks straight as an arrow; however, when I hit a bump (or even a large crack) in the road, the car pulls to the right. It almost feels like I'm about to lose my back end in a fishtail. I have yet to really feel unsafe, but something definitely is not right. Any recommendations as to what to look into?
Re: Swaying Issue
Posted: Sun Sep 21, 2014 3:55 am
by MrJiggy716
any known suspension issues? Id start to inspect there...
Re: Swaying Issue
Posted: Sun Sep 21, 2014 7:00 am
by crash93ssei
Bad rear shocks are known to cause this exact issue as well as a broken toe link on the rear control arm.
Re: Swaying Issue
Posted: Sun Sep 21, 2014 9:41 am
by nos4blood70
+1 on bad rear shocks. Very easy to replace and inexpensive.
Re: Swaying Issue
Posted: Mon Sep 22, 2014 8:38 am
by gap1533
I checked shocks with the ol' bounce test and each corner returns to rest after just a couple of bounces. Is there a more definitive test I can do at home to test shocks?
Re: Swaying Issue
Posted: Mon Sep 22, 2014 9:19 am
by crash93ssei
The bounce test should pretty much cover it, bounce it really hard and it should return to normal after only one or two bounces. Other then that I would look at the toe links.
Re: Swaying Issue
Posted: Mon Sep 22, 2014 7:43 pm
by gap1533
So, toe links appear to be good, but I got a better visual on the rear struts today and they look pretty crappy. Both have some fluid visible and the passenger side (the side which the vehicle sways to) has a lot of build-up and the "boot" on the bottom of the strut is pretty tore up. Unless anyone has any other ideas, I think I might just dive into these and hope for the best.
Before I do though... I haven't found a great way to support the back end. The only good jack points I've found are the same points where I would want to place my stands which causes an issue. I haven't found two good spots on the same side.
Re: Swaying Issue
Posted: Mon Sep 22, 2014 9:26 pm
by crash93ssei
I jack up and use jack stands right on the rear subframe, check this thread out for easy replacement of the shocks. http://www.pontiacbonnevilleclub.com/fo ... 39750.html
Re: Swaying Issue
Posted: Mon Sep 22, 2014 9:32 pm
by gap1533
Tons of help. Thanks!
Any thoughts on replacing shocks too? What about doing the back struts, but not the fronts. Issues here?
Re: Swaying Issue
Posted: Mon Sep 22, 2014 9:48 pm
by crash93ssei
That is for the rear shocks ;)
Re: Swaying Issue
Posted: Wed Sep 24, 2014 4:19 pm
by gap1533
One more thought before replacing the struts....
Since they operate on compressed air, would I be able to diagnose bad struts by unnecessary running of the compressor system? The compressor is working well. The vehicle levels and adjusts occasionally, but does not run more than it should. This leads me to believe that all is well. Is this reasonable?
Re: Swaying Issue
Posted: Wed Sep 24, 2014 5:08 pm
by crash93ssei
The rear only uses air to level the car not for shock absorption. The air bladders could still functionally be fine but the shock itself be wore out. Front suspension uses struts while rear uses shocks on the 2000+ Bonnevilles.
Re: Swaying Issue
Posted: Wed Sep 24, 2014 6:33 pm
by gap1533
Very interesting. Thanks for being patient with me, as I am learning as I go. Also... just clarified the difference between a shock and a strut via a YouTube vid and things are making a bit more sense. Thanks again!
Re: Swaying Issue
Posted: Wed Sep 24, 2014 7:49 pm
by crash93ssei
No problem at all, that is why this place exists :) don't be afraid to ask any questions you may have, we all started somewhere!
Re: Swaying Issue
Posted: Thu Oct 02, 2014 3:10 pm
by gap1533
Finally found the time to replace the rear shocks and Bonnie drives like a new machine. I'm keeping my fingers crossed, but from a test drive along the very roads which used to make me feel like I was riding waves, all is well.
Thanks Ryan for the replacement video and for the product suggestion. I ended up using the KYB SR1002 shocks as well. This project was certainly worth the $77 and 2 hours of my time!
If any issues arise or persist, I'll share with you all, but otherwise assume all is good!
Re: Swaying Issue
Posted: Thu Oct 02, 2014 5:35 pm
by crash93ssei
Glad to hear it went well for you!
