Fuel pump stuff GONE. Thanks to all.
Posted: Thu Sep 18, 2014 3:40 pm
Guys (and gals) I'm out of the Bonneville business. I just bought a new Ford Fusion, no more Bvilles, so I'm cleaning out my garage and tool box of lots and lots of spare parts.
If you're going a fuel pump swap soon, please take the following stuff off my hands for only shipping from 95020.
OK, here's box 2: gas tank stuff.
2 pieces of expensive tubing (5/8" and 1 1/2") for swapping out the fuel pump or gas tank. These never come out in one piece and I think I paid about $20 for both. It cuts an easy hour off replacing a fuel pump just to cut the *dang* things off and replace with new.
3 fuel pumps. 1 in-op, 2 good-you check 'em out, not sure which one is bad. I include an electrical fitting for the pump so you can run it for a few seconds off the battery to check function.
fuel tank lock ring, plus 2-3 fuel tank lock ring gaskets.
Several lengths of fuel-injection rated hose. (again, expensive)
2 of the three tank to fuel filter plastic fuel lines, none for the bottom (vacuum one)
the metal nipples off the fuel tank end of the fuel tank/fuel pump assembly (handy for patching either end of hoses) plus several of the plastic fuel line clips.
One entire pigtail of the fuel tank wiring harness, pump, gauge and pressure valve in case you have to patch in, with end sockets intact.
Again, all this is fo' free, shipping only from 95020. PM me. Somebody grab these quick or it's the recycle bin. I'd rather a Bonneville brother got them.
