Which brake Pad Set?
spoiledred94
Post by spoiledred94 »
Oreilly's Cheap Brake Best Select Ceramic
Cheaper and Improved Performance. It also comes with some limited hardware/
Wagner Thermo Quiet Ceramic Pads
Better Performance-durability and heat dissipation. Also comes with hardware and bigger price (by$20)
I want to save the money and I may not need any improved performance over the Brake Best Select. I don't drive very hard for very long or often. I bought D/S Rotors for the added effectiveness in wet conditions and hopefully to last longer with the extra cooling of the holes. I want to do the pads at the same time.
Would I be making a mistake if I go with the Brake Best Select?
:dontknow:
great car. Wrecked
Burnt Bonny.
AJT2004
Re: Which brake Pad Set?
Post by AJT2004 »
Did you checkout RockAuto? You can get Akebono (ACT699) which includes hardware for $60.79. They also offer less expensive choices as well. Don't forget to use the 5% discount code.
spoiledred94
Well I intended this to be a question of the two I listed. I am basically asking if there is a significant difference in quality of the low priced ceramics and the high priced Ceramics.
I appreciate your input and am considering all my choices.
great car. Wrecked
Burnt Bonny.
cooljoe51
Post by cooljoe51 »
My personal experience with the Wagner pads is that they cause a lot of dust (at least in my case). I'm not sure about your other ones. I put Raybestos pads and rotors on over a year ago and I'm still happy with the performance and dust on mine! Just my two cents.. good luck though!
[IMG]http://i1060.photobucket.com/albums/t442/cooljoe51/538189_10150873383431500_593211637_n.jpg[/IMG]
spoiledred94
I bought the Brake Best Select Ceramic pads. Comes with the basic hardware. These along with d/s Power Stop rotors should clear up my pulsating steering and brake pedal and help retain braking performance when its seriously raining. I've not been performance bound on most of my repairs since I got this car. But when it comes to brakes better performance is demanded.
BrakeBestSelect Ceramic
great car. Wrecked
Burnt Bonny.
spoiledred94
I chipped a tiny bit of an edge off the pad material. How serviceable would this pad be?
great car. Wrecked
Burnt Bonny.
spoiledred94
Finished it, They're in right and the brakes work well. Couldn't compress the caliper on the drver side for a while. Should have rebuilt the caliper.
:P
thx
great car. Wrecked
Burnt Bonny.
