question for you abs gurus,,,,
02 bonnie beast
Year and Trim: 2002 ssei
Post by 02 bonnie beast »
i have replaced both hubs in the front, and i have also replaced the brakes all the way around. and i still get a code from the abs that says that the left front hub is either open or shorted. i check the wheel speed sensors during operation of the car, and all four of them register, then when the code flashes, the sensor says zero mph. i know the hub is good, and the sensor is good as well as i have tested the continuity and ac voltage of it. everything is fine with it. i am leaning toward the wiring being bad, and was wondering if this seems to you all like a viable fix?
Re: question for you abs gurus,,,,
Perhaps it's just a piece of corroded wiring somewhere.
02 bonnie beast
yeah that's what i'm thinking. i wanna buy one of the repair harness kits and see if that doesn't fix the issue
bobgto65
2004 Bonneville GXP
Post by bobgto65 »
I had a Trac Control error on my o4 GXP and when I disconnected the EBCM wire harness connector and the ECM connectors and re-connected them, the code went away
bobgto65
02 bonnie beast
bobgto65 wrote:I had a Trac Control error on my o4 GXP and when I disconnected the EBCM wire harness connector and the ECM connectors and re-connected them, the code went away
very interesting. i will try this in the morning. thanks.
1tinindian
Year and Trim: 2004 SLE Premier Edition
2005 GXP
Post by 1tinindian »
I see this often at the dealership.
I have replaced the ABS harness, after locating a bad section.
Usually in an area where the wire is subjected to a lot of twisting motion while the car is being steered of suspension is moving up and down.
Use a multimeter and move the wire around until you can find the bad section in the wire.
You will see the gauge move when the bad spot is found.
Leon
2006 GTO
2005 GXP Bonneville (his) (SOLD)
2004 SLE Bonneville (hers)
2004 SLE Bonneville (sons)
2006 GXP Grand Prix (sons)
1998 SLE GMC Sierra
1991 Yamaha FJ1200
1983 Trans Am (SOLD)
1979 Trans Am
02 bonnie beast
1tinindian wrote:I see this often at the dealership.
Leon
the replacement harnesses are only 20 dollars a piece from dorman., so i'm just gonna do that.
