Are GXP calipers a direct swap?
Posted: Tue May 13, 2014 8:54 am
by MurderMitten
If I get some GXP calipers for my SLE, what do I need to do to put them on? Are the line fittings the same? Do they bolt on the same and do I need bigger rotors?
Re: Are GXP calipers a direct swap?
Posted: Tue May 13, 2014 11:25 am
Yes, you need the proper rotors. Usually the calipers come with the brake lines (little different), although old rubber brake hoses aren't always the smartest thing to reuse. They bolt on the same, but you also need the special bolts that the GXP calipers use.
Posted: Tue May 13, 2014 11:30 am
by MurderMitten
If I take the calipers off a junkyard GXP I have the bolts only.thing is that whoever pulled the engine just cut the brake lines instead of just undoing the lines so id need new lines
Posted: Tue May 13, 2014 11:37 am
Parts store should be able to get you new lines. That's not a biggie.
Posted: Tue May 13, 2014 4:09 pm
by crash93ssei
For GXP front brake swap you need calipers, caliper slide bolts, brackets, bracket bolts, and the flex brake lines. All of these are must have items, without them it won't work as they are specific to that setup.
Posted: Thu May 15, 2014 11:58 am
by jnl518ssei
Not trying to highjack the thread,but what about the rears?
Posted: Thu May 15, 2014 12:18 pm
by crash93ssei
Rears you need the brackets and maybe the bolts, but the calipers are the same.
Posted: Thu May 15, 2014 11:37 pm
by optimist prime
Looks like ill be doing a j/y run for mine also
