my 2005 bonne gxp tranny stuck in reverse
Posted: Sat May 10, 2014 11:54 am
by bigrod64
hey guys i was wondering if anybody else had this problem before.I went to the car wash the other day and as i was sitting in line with the car running the guy in front of me needed to back up,so i put my car in reverse to give him room. And as i did this the car moved as normal,but when i put it back in drive to go forward it went BACKWARDS and i thought for a second i had it in :dontknow: the wrong gear so i looked down to make sure and low and behold it was in drive so hit the gas and it still went backwards,then i put it in (n) same result (p) same result then i shut the car off to restart it (nothing) the dang thing would not start back up. :dontknow:
Re: my 2005 bonne gxp tranny stuck in reverse
Posted: Sat May 10, 2014 12:06 pm
by harofreak00
Sounds like the shifter cable came off the transmission.
Posted: Sat May 10, 2014 12:15 pm
by CMNTMXR57
Yea, that would be the nuetral safety switch not allowing it to start again.
Could be the cable as mentioned above (either off the trans or out of adjustments), could also be a bad shifter assembly sending the wrong (or no), signal to the BCM. Not sure how fancy ours was as I never faced that problem, but some GM's have very tempermental prox switches in the shifter assembly that when they go south, can generate issues or DTC's and error messages (Shift to Park is a common one).
Posted: Sat May 10, 2014 12:44 pm
by bigrod64
thanks for the quick reply guys,the car is at the shop as we speak,just kinda needed a heads up on what might be the problem im hoping thats a quick fix and not the tranny its self,i will give you guys the update on it in a couple of days unfortunatly the shop is not open on weekends :eek: THANKS.
Posted: Sat May 10, 2014 9:57 pm
by harofreak00
If you have any mechanical knowledge at all, putting the shifter cable back on would be a 1 minute job. Just look directly below the brake booster and see if its attached. If not, pop it back on, it just snaps into place.
