Only ONE dome light will not go off
Posted: Fri Mar 14, 2014 10:21 am
by jcweis1
I tried searching but could not find anything.
The rear passenger dome light over the door will not go out but the rest of the interior lights will.
I pulled the bulb to keep the battery from going dead which now the remainder of the interior lights do not come on.
Sure need the help to figure out the repair.
thanks
Re: Only ONE dome light will not go off
Posted: Fri Mar 14, 2014 10:53 am
by MurderMitten
Did you make sure the button was pushed in(turned off)? Sounds like a stupid question but it happens..
Posted: Fri Mar 14, 2014 10:55 am
by jcweis1
Yes the switch is fine. All lights go out as they should except the one over the rear passenger door.
Posted: Fri Mar 14, 2014 11:46 am
by harofreak00
Why would you say the switch is fine if the bulb never goes off? I would say the switch is bad.
Posted: Fri Mar 14, 2014 11:59 am
by jcweis1
The switch on the dash seems to work fine- it turns the all the interior lights on and off except for the rear passenger door light. Am I missing something? Does this switch have to wiring to control all lights individually??
All the interior dome lights go on and off as they should with the doors opening and closing and turning the dask switch on and off - except for the rear passenger door
Posted: Fri Mar 14, 2014 12:25 pm
There's a little button to turn it on and off in the back, if someone were reading a book, etc. I wonder if a passenger didn't bump it? That'd be my first suspicion.
Posted: Fri Mar 14, 2014 12:32 pm
by jcweis1
OH now I know what you meant. I didn't know there was a buttom back there. I will check for that.
No one rides in the back, I am the only one in the car to use for transportation to and from work.
Posted: Fri Mar 14, 2014 11:14 pm
by DaMaroon
The door pin switch, that turns the light on when the door is open, is stuck on. Push it in and let it snap out a few times. Tap on it's base with something hard to get it to release.
Posted: Mon Mar 17, 2014 11:49 am
by jcweis1
Finally had time to look at the problem and LOL knowing there was a switch at the light above the rear doors. The switch is bad. The switch would turn off when it was pushed but click back to the 'on' position by itself. Now all I have to do is find a replacement switch which should be fun.
Posted: Mon Mar 17, 2014 12:05 pm
by Archon
Pull the bulb for now, then send a private message to Andrew (Harofreak00) to see what he may have for the switch.
Posted: Mon Mar 17, 2014 9:26 pm
Might just need to buy the whole grab handle.
Posted: Tue Mar 18, 2014 7:06 am
by jcweis1
Replacing the whole grab handle does look like the way to go. I have yet to take it apart but looks like removing the two screws will remove it. I still cannot get over that I did not know there was a switch located at the light!
Posted: Tue Mar 18, 2014 9:37 am
by mrwildroot
Like me, you probably don't drive from the back seats much...
Posted: Tue Mar 18, 2014 11:48 am
by harofreak00
I got a grab handle for cheap if you need one.
Posted: Tue Mar 18, 2014 11:51 am
by jcweis1
What color and price?
Posted: Tue Mar 18, 2014 11:52 am
by harofreak00
Any color you need, PM me.
Posted: Tue Mar 18, 2014 11:58 am
by jcweis1
PM sent thanks for the offer
