Whine
Posted: Wed Jan 29, 2014 1:46 am
by blackbeauty99
I call it my pretend supercharger..haha..but no really, what causes this whine under acceleration? is it just a series II common thing? because I have heard an oldsmobile that does the same thing..none of our old L27 motors did this...
Re: Whine
Posted: Wed Jan 29, 2014 11:16 am
by J Wikoff
The power steering pump is a usual culprit.
Re: Whine
Posted: Wed Jan 29, 2014 11:18 am
by gonzo4191
CheckYourFluid. It's Behind The Passenger Side Under The Alternator
Re: Whine
Posted: Wed Jan 29, 2014 12:02 pm
by repinS
Low transmission fluid can cause a whining noise also.
Re: Whine
Posted: Wed Jan 29, 2014 12:15 pm
by J Wikoff
Good point. Does it change with RPM or vehicle speed?
Re: Whine
Posted: Thu Jan 30, 2014 2:53 am
by blackbeauty99
both are full, it does it with an RPM increase...its done it since I got the car...bought it with 160 and now has 172. Performed flawlessly, she is due for a tranny flush though..I took it in for an oil change since it was super cold out...they said the fluid was getting dark...
Re: Whine
Posted: Fri Feb 28, 2014 12:24 am
by bad.moshi
Always wondered this myself. Mine does the same thing accelerating up to about 25 mph. I'm sure it does it after that as well, but then the engine noise is louder and it fades out. Whine increases with speed, RPM, you name it. Fluids are good in my case too. Best I could figure is that somehow it seems that there is a cover missing under my car that seems to expose the teeth of a large gear slightly (flywheel?).
Typing that out makes it sound dangerous, but I've noticed it ever since I dropped the pan on my transmission the very first time when I bought the car. You can see it near the pan and again you can see it peaking through just beside the starter. Anyhow, I have no evidence of that being the case, but I imagine maybe our cars are allowing more sound out because of it. Who knows?
Re: Whine
Posted: Fri Feb 28, 2014 9:05 pm
by bmoseman
My whine ended up being the ac compressor pulley bearing.
