running lean
Posted: Tue Dec 17, 2013 8:10 pm
by Bonneville_ssei_00
I recently had the supercharger off and now back together and driving good till the other day I threw a code on my car is said it was running lean Bank 1. do any of u guys know on how to fix it?
Re: running lean
Posted: Tue Dec 17, 2013 8:22 pm
by harofreak00
Probably a vacuum leak. Check all the vacuum lines.
Re: running lean
Posted: Tue Dec 17, 2013 8:48 pm
by 95se
My favorite way is to use carb clean on vac lines but i cannot stress enough to do this very carefully with a hot engine. When you spray the carb clean on a cracked vac line or leak the engine will idle higher than normal.
Re: running lean
Posted: Tue Dec 17, 2013 8:49 pm
harofreak00 wrote:Probably a vacuum leak. Check all the vacuum lines.
I found one that might be the problem it the T that goes in the fuel regulator so I rapped it with duct tape for now till I can get a new one. hopefully that's the problem. thanks.
Re: running lean
Posted: Wed Dec 18, 2013 12:01 am
The t's are a dealer-only part if you want the OE style, otherwise you can buy the right size hose and use the little plastic T's that come in a Dorman HELP kit at your local parts store.
Re: running lean
Posted: Mon Dec 23, 2013 5:06 pm
by 95se
I robbed about 6 t fitting at the junkyard over the summer, because mine split apart. Must be common for them to split huh?
Re: running lean
Posted: Mon Dec 23, 2013 6:03 pm
by Zeik75
I ended up getting the dealer part for that because of time,, i think it was around 45, next time though I plan to make something that will last a bit longer and be a bit tougher.
