03 SE CHUGGING VIDEO
Posted: Mon Dec 16, 2013 3:59 pm
by 1997SEgreenmonster
Image what could cause this ???????????
Re: 03 SE CHUGGING VIDEO
Posted: Mon Dec 16, 2013 4:56 pm
by samples08
Can you do that from the motor side of the car?
Posted: Mon Dec 16, 2013 5:46 pm
by harofreak00
When is the last time you did a tune up? Plugs and wires?
Posted: Mon Dec 16, 2013 5:50 pm
by J Wikoff
It's in gear in the video? Does it chug in park?
Posted: Mon Dec 16, 2013 6:43 pm
by samples08
harofreak00 wrote:When is the last time you did a tune up? Plugs and wires?
:banana: we were thinking same thing why I wanted an engine side video to double check the sound!
Posted: Mon Dec 16, 2013 8:28 pm
yeah its in gear. I have tried it in park but it wont do it.
J Wikoff wrote:It's in gear in the video? Does it chug in park?
Posted: Mon Dec 16, 2013 8:32 pm
Haro i had plugs and wires done on it back in the spring and thats when it started acting up. A few weeks ago i had the front motor mount replace and was getting a misfire from plugs 3/6 so i changed those and one of the mount on the backside of the motor was change and it ran fine for a few days then went back to chugging and bad idle once car is warmed up
Posted: Mon Dec 16, 2013 8:38 pm
The only one i have is it running idle but its not acting up
samples08 wrote:Can you do that from the motor side of the car?
Posted: Mon Dec 16, 2013 11:32 pm
by nos4blood70
Coils and ICM?
Posted: Mon Dec 16, 2013 11:47 pm
by repinS
What brand and type of plugs went in?
Posted: Tue Dec 17, 2013 12:05 am
by samples08
1997SEgreenmonster wrote:The only one i have is it running idle but its not acting up
Put it in gear apply parking brake and slightly pull on the throttle body accelerator, as your recording the video
Posted: Tue Dec 17, 2013 9:01 am
by BlackHawk99
How old is your fuel filter?
Posted: Tue Dec 17, 2013 4:15 pm
I changed the fuel filter back in the spring when i did the plugs and wires
BlackHawk99 wrote:How old is your fuel filter?
Posted: Wed Dec 18, 2013 9:12 am
by BlackHawk99
I'd check your fuel pressure at the rail. Either tape the guage to the windshield so you can see it, or have someone else in the car put the car in drive and hold the brake while slightly pressing the gas pedal. IIRC, the pressure should be ~42 lbs of pressure. If you're seeing significant drops then you have a weak pump, clogged filter, or faulty pressure regulator.
The lack of CEL and the fact that it only does this under a load makes me think it's fuel related. That has been my experience in the past with similar situations.
Posted: Thu Dec 19, 2013 3:00 pm
This is the best i can do but here is a video of the motor and chugging outside of the car
Posted: Thu Dec 19, 2013 3:26 pm
Here is a video of the motor
Posted: Thu Dec 19, 2013 3:35 pm
by J Wikoff
Does it ever not chug? Always chugging? Does it get worse under certain conditions?
Posted: Thu Dec 19, 2013 3:38 pm
It chuggs under load or after warmed up when sitting in park drive or reverse when its cold it really hasnt done. But it never does it while sitting in traffic on when driving in traffic
J Wikoff wrote:Does it ever not chug? Always chugging? Does it get worse under certain conditions?
Posted: Thu Dec 19, 2013 4:17 pm
I went with AC DELCO 41-101 PLUGS AND BELDEN WIRES from napa
repinS wrote:What brand and type of plugs went in?
Posted: Thu Dec 19, 2013 10:44 pm
by BlackHawk99
Did you check your fuel pressures?
