Remove sticker from rear window
Posted: Fri Nov 15, 2013 10:09 pm
by imidazol97
What works to remove a small college sticker from the inside of the rear window without damaging
the defogger stripes?
WD-40 doesn't seem to be doing the job working on the adhesive.
Re: Remove sticker from rear window
Posted: Fri Nov 15, 2013 10:44 pm
by MrJiggy716
Goo gone will be your friend...
Posted: Fri Nov 15, 2013 11:18 pm
by nos4blood70
Try Goo Gone and gentle scrubbing.
Posted: Sat Nov 16, 2013 3:52 am
by Evan0801
razor blade (be careful)
Posted: Sat Nov 16, 2013 7:13 am
by 1oldman
Evan0801 wrote:razor blade (be careful)
I'd say super duper careful. I've done it once with a razor blade. I thought it was the most labor intensive. - BC
Posted: Sat Nov 16, 2013 5:19 pm
by 02Bonney
definitely Goo Gone.
Posted: Sat Nov 16, 2013 7:17 pm
by Jfridge92
Definitely goo gone, I used that stuff all the time when I worked with vinyl lettering. You could also maybe try using a heat gun to soften the sticker, just be careful and don't leave it in one place too long (and obviously if the window is freezing don't use a heat gun to avoid cracking it). You could try a hair dryer, that would be a little safer if it's really cold.
Posted: Sat Nov 16, 2013 7:24 pm
by Arrowhead
You might try paint thinner/ mineral spirits, a pretty mild solvent that works pretty well on sticky stuff in my experience.
Posted: Sun Nov 17, 2013 2:34 am
by bobgto65
The goo gone will easily remove adhesive residue but you have to remove the decal first to get to the adhesive (unless it is paper). The heat gun may soften it up enough to peel it off or use your fingernail or a razor blade, but stay away from the wires when using the razor blade.
Posted: Sun Nov 17, 2013 2:47 pm
by KelvinVV
I've used rubbing alcohol to get stuff off of my windows, and it works pretty well. As for scraping, use a plastic putty knife or your finger nails and you should be in good shape.
Posted: Tue Nov 19, 2013 3:28 pm
by Zeik75
Arrowhead wrote:You might try paint thinner/ mineral spirits, a pretty mild solvent that works pretty well on sticky stuff in my experience.
Lol i'll take your word for it.
Posted: Tue Nov 19, 2013 3:57 pm
by Arrowhead
Zeik75 wrote:Arrowhead wrote:You might try paint thinner/ mineral spirits, a pretty mild solvent that works pretty well on sticky stuff in my experience.
If ya really want to open a can of whup-azz, you can try toluene, MEK or methylene chloride.
