Page 1 of 2
Bad Motor Mount
Posted: Thu Oct 17, 2013 7:15 pm
by Jatlec26
I went in to Mavis Discount Tire today to get my Bonnie aligned because my steering wheel was cocked at about a 45 degree angle, give or take. While I was watching them do the alignment, the guy working on my car called me over and told me I have a bad motor mount. He said they don't fix those there, but I should get it fixed.
How much money should it be to fix/replace the motor mount?
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 7:32 pm
Which one? I'm assuming the front one? If it is: http://www.pontiacbonnevilleclub.com/fo ... 36054.html
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 7:39 pm
by samples08
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 8:33 pm
by flatlander745
If it is actually the "motor" mount then it would be this:
https://www.rockauto.com/catalog/x,carc ... ttype,5552
otherwise follow previous instructions.
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 9:01 pm
by Jatlec26
He didn't specify which mount, and I'm pretty new to this stuff. So I don't really know.
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 9:13 pm
by harofreak00
If it was in the front, it was the front trans mount, as there is no front engine mount.
The hockey puck is the original solid mount, but I've found that 3" boat rollers are cheaper and easier to find, and you don't need to drill the hole in them either. Just get an 8" long 1/2" bolt, some washers, an old swaybar bushing, and a locking nylon insert nut.
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 10:38 pm
by repinS
harofreak00 wrote:The hockey puck is the original solid mount, but I've found that 3" boat rollers are cheaper and easier to find, and you don't need to drill the hole in them either. Just get an 8" long 1/2" bolt, some washers, an old swaybar bushing, and a locking nylon insert nut.
Real easy to find hockey pucks for 75 cents each up here in the Great White North, eh :canada:
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 11:21 pm
by harofreak00
Boat rollers are around $3 ;)
Re: Bad Motor Mount
Posted: Thu Oct 17, 2013 11:32 pm
Sheesh, I paid like $3 apiece at Sports Authority here, and I'm in the "land of hockey"...
Re: Bad Motor Mount
Posted: Fri Oct 18, 2013 12:22 pm
by Archon
I used the hockey pucks on my car, and a boat roller on a friend's. Between the two, I'd also suggest the boat roller. Not having to drill the holes, and making sure they're lined up is a big plus as far as a time saver. The roller is a little softer rubber, making it easier to dampen vibrations for those sensitive to it.
Re: Bad Motor Mount
Posted: Fri Oct 18, 2013 3:01 pm
by nos4blood70
Yeah I was gonna ask, is the vibrations difference hugely discernible between the two options?
Re: Bad Motor Mount
Posted: Fri Oct 18, 2013 6:51 pm
by Jatlec26
Is the reason my car vibrates at idle because of the bad motor mount? And would anything really bad happen if I didn't fix it for a while or is it a must fix?
Re: Bad Motor Mount
Posted: Fri Oct 18, 2013 7:07 pm
by nos4blood70
You run a risk of cracking the trans housing, IIRC.
Re: Bad Motor Mount
Posted: Sat Oct 19, 2013 12:34 am
by Archon
nos4blood70 wrote:Yeah I was gonna ask, is the vibrations difference hugely discernible between the two options?
Hugely? No.
I tried the hockey pucks alone to start, and didn't care for the vibration at all. I used some neoprene washers, and the bushings from an old endlink, and still found it too much for my taste. By using various rubber grommets, I was able to get it to a level I could live with. I was able to use fewer with the boat roller, and the vibration is slightly, but noticeably less.
Re: Bad Motor Mount
Posted: Sat Oct 19, 2013 8:32 am
by younggunls1
Re: Bad Motor Mount
Posted: Sat Oct 19, 2013 10:27 am
by nos4blood70
^ That's so funny to watch. "Shake it!" LOL
Re: Bad Motor Mount
Posted: Sat Oct 19, 2013 11:07 pm
by Jatlec26
Is this a fairly easy thing to do? If it is, can somebody give me a list of supplies to buy? I think I'd rather go with the boat roller idea.
EDIT: Or should I buy one of the mounts suggested earlier in the thread?
Re: Bad Motor Mount
Posted: Sun Oct 20, 2013 3:06 pm
by swampthing
I went through several stock style mounts including a supposed solid one from auto zone. They all fail, its a bad design.
I did the boat roller as well no complaints here
Re: Bad Motor Mount
Posted: Sat Dec 28, 2013 10:14 pm
by 731Loadmaster
Can someone please give a detailed parts list for the Roller Mount? I have the pucks but would really like to have a back up if possible. And Where in the Heck do I find 7 1/2" - 8 1/2" bolts? Lowe's and HD don't have them.
Wolf
Re: Bad Motor Mount
Posted: Sun Dec 29, 2013 10:59 am
by samples08
wolf I got my bolt and washers and nut all at Lowes very cheaply I must say, the roller is a new design that I had not yet heard about I had to order the pucks from up north but it was very easily assembled and works extremely well especially when you get into it you can tell the difference!
