Car stops accelerating under power
ricosuave420
- GXP Member
- Year and Trim: 1993 ssei supercharged bright white
Hi all, a week ago I noticed my check engine light came on for 30 seconds then went out, then yesturday it came on again then went out, I figured it was emissions because I failed emissions, then my mechanic took the car, 2 hours later it somehow passed, which is why I figured it was due to emissions but then today I decided to see if it would miss so I gave it about 2 pounds of boost, it was fine for 2 seconds, then the light came on and, it didnt miss bc I know what a miss feels like, the engine more or less just stopped accelerating then after 2 seconds the light went out and the engine was back at full strength. I just replaced the plugs, denso iridium with MSD wires both replaced in may about 3000 miles ago. What in the world is going on here, I use shell premium, replaced the fuel filter 10k miles ago and use Mobil one synthetic, does anyone know what's going on here. ( also I replaced the supercharger about 2 1/2 years ago)
1993 SSEI SUPERCHARGED AKA "ANGLE"
180,000 MILES
2000 WATT SYSTEM, ALPINE 7 INCH FLIP OUT TOUCH SCREEN TV, 2 12" SUB WOOFERS IN THE TRUNK
2000 WATT ALPINE AMP
LADIES CALL IT A ROLLING CLUB, I GUESS THE VIBRATIONS GET THEM READY FOR SOME FUN
SSEI= SSEXI
NOW WITH BEAUTIFUL BLUE NEON UNDERGLOW
CERTIFIED EAGLE SCOUT MAY 19 2009
REFERRED TO BY EVERYONE AS JAMES BONDS WEEKEND CAR, REFERRED TO BY ME AS ANGEL
180,000 MILES
SSEI= SSEXI
- J Wikoff
- Year and Trim: 1992 SSE
Re: Car stops accelerating under power
Knowing the code would be a good start. Check out tech info for the paperclip method to get the SES light to flash the code numbers.
ricosuave420
- GXP Member
Do you know if the computer logs the error code, bc the light only pops on for 30 second intervals once, mabey twice a day
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
- MattStrike
- Year and Trim: '99 Montana
It stores the code, unless there's a problem with the computer.
- Jfridge92
- Posts like an L67
- Year and Trim: 1999 Buick Lesabre Custom
When the SES light comes on, is it a steady light for 30 seconds, or does it flash at all?
But as has been said, the code that's stored will help us a lot to point you in the right direction.
Joseph
1999 Infiniti G20T - Sold
motopsyco
- SSEi Member
- Year and Trim: 1992 SE
if it just stops accelerating when that light is on (probably wont want to go over 45mph too right?), then I'd have to say your computer thinks (and probably is) its something bad, sounds like 'limp home mode' to me, could be caused by a knock sensor or something. when it goes off the car thinks its ok again and runs normal. Had this happen a couple times with my old 91 firebird when it said the knock sensor was bad, although it straightend itself up after that and never had a problem with it again. But like they said said read the code, to find out what it stored.
Recently my fuel pump went out; no real warning, it all happened within twenty minutes. I was driving, engine sounded a little strange but ran decent. Out of nowhere the Low Trac light came on, and eventually the CE light snapped on, at which point I pulled over and turned off the car. Intake was already done so I wasn't worried about that. However my car wouldn't start back up for twenty+ minutes. When it did, it ran horribly, and it seemed the more gas I gave it, the less it would move...like I was pressing the brakes instead. Long story short, the fuel pump gave out and registered zero fuel pressure at the rail. Perhaps you should check your fuel pressure?
ricosuave420
- GXP Member
Turned out to be the throttle body sensor, never even herd of something like that
180,000 MILES
SSEI= SSEXI
180,000 MILES
SSEI= SSEXI
