Parts Interchange Question
Posted: Fri Sep 06, 2013 9:00 pm
by donn188
Buddy has a 01 Grand Prix GT that will be going to the scrapyard soon - I already plan on getting everything I can from the A/C system, coils and other misc motor parts but everything was in perfect mechanical condition before the windows were smashed out of the car so I'm curious if there are any other parts that I should pull to have on hand that will work on my 00 SSEI. Thanks in advance for any advice! :eek:
Re: Parts Interchange Question
Posted: Fri Sep 06, 2013 11:43 pm
by bobgto65
We had a 98 GP GT and I do not recall much on there that will work in the Bonneville other than some of the engine parts that you mentioned. There is really nothing in the interior that you can use to the best of my knowledge. You can save some bulbs like the for the headlamps, taillamps, , fuses and relays.
Posted: Sun Sep 08, 2013 4:20 pm
by Jfridge92
Don't use the coils from that Grand Prix on your SSEi if it's a GT. If it's not supercharged, the coils on your L67 in the SSEi are stronger than his GP coils. They'll work and bolt up, but they're slightly weaker.
Posted: Wed Sep 11, 2013 10:35 pm
by donn188
Well I have a random miss in one of my cylinders that happens whenever it pleases - the only thing I havn't replaced is my coil pack so I think I'd rather know they're newer and work 100% if it would'nt cause any problems.
Posted: Wed Sep 11, 2013 11:15 pm
by Wes
They will work just fine for that, but as mentioned they have a slightly lower output voltage.
Posted: Thu Sep 12, 2013 6:29 pm
by donn188
Are the fuel tanks the same or different? Should I expect any problems with the A/C parts bolting right up?
Posted: Thu Sep 12, 2013 6:47 pm
by Wes
I would guess no on the tank. But, for that, and the A/C parts you are interested in taking, I would just open rock auto in two tabs, and compare part numbers.
