no power with rotten egg smell and coding p0300
bonnelover
Post by bonnelover »
Hi,
Today, from out of no warnings, my car started idling really bad and now it doesn't have much power :sad: it also smells like rotten eggs. From what I have read, it almost sounds like the catallactic converter is bad. If so, what is the factory warrany on them and what causes them to go bad?
I just called OnStar and they ran a diagnostic test and it is coding p0300
Thanks
05 SLE
-Other rides: 2010 Buick Lacrosse, 1987 Dodge Dakota, fully restored
November 2010 COTM
crash93ssei
Re: no power with rotten egg smell and coding p0300
Post by crash93ssei »
P0300 is multiple cylinder random misfire.
Unplug the MAF sensor and see if it runs any different. The rotten egg smell and loss of power is likely caused by the misfiring, unburnt fuel is going through the catylitic convertor and trying to burn off giving a sulfur smell. If the MAF makes no difference, pull the plugs and see how they look, could be time for some new plugs and wires.
Seems like I remember the warranty on the cat being around 80,000 miles or so.
bonnelover
what if it runs differently without the MAF sensor? also, what is the likelihood of it being the coil packs?
thanks
05 SLE
November 2010 COTM
crash93ssei
Coils could also be the cause, if you have extras, swap them out as well just to see.
If it runs better with the MAF unplugged then it is bad. If it runs worse or the same then it is likely not the issue.
bonnelover
i did the unplugging and it ran the same :( i read on here where someone tested their coils by spraying a mist of water on them, i wonder will that work.
05 SLE
November 2010 COTM
crash93ssei
I usually pull one plug wire off the coil and start the engine, you should be able to hear / see the spark jumping from the top of the tower to the base of the coil, you can do this at night to make sure you see it if you want. Do one at a time, all six should spark good enough to hear pretty easily.
bonnelover
thanks, i will give it a try
05 SLE
November 2010 COTM
Also, the spark from the coil will arc a good distance and loves your fingers. Ask me how I know. XD
SSEiMan01
Post by SSEiMan01 »
nos4blood70 wrote:Also, the spark from the coil will arc a good distance and loves your fingers. Ask me how I know. XD
Still the best way to ask a girl to prom. :lol:
James May wrote:Hello.
redzmonte
Year and Trim: 2000 SSEI
Post by redzmonte »
Cats have a 8yr 80K mile warranty. if your getting a stong smell, low power and missfire it is very likely its getting plugged. any mods to the car? cats usually fail from excess fuel.. might have something going on that caused a cat failure. if you have a lazer temp thingy then you might want to start the car and warm it up and read the temps on the inlet of the cat and outlet and see what they read. should be 150*+ higher at the outlet of the cat.
Also if its stock cat then you can unbolt the flange and look to see if the cat is melted.
Good cat: has nice even honeycombs inside
Bad Cat: Broken pieces or melted
Shane "RedZMonte"
2004 Z16 Z06: Virgin
bonnelover
only mod is cold air intake, car has 67,000 miles on it
05 SLE
November 2010 COTM
bonnelover
I tested the coil packs tonight. One pack has no fire at all. One pack has a lot of fire, and one pack has a lot of fire on one wire and not as much on the other. Hopefully, replacing them will correct the problem?
05 SLE
November 2010 COTM
bonnelover
:sad: replaced the coil pack and still no fire
05 SLE
November 2010 COTM
crash93ssei
Just to make sure, swap one of your known good ones to that spot. If still no fire, likely the ICM is the problem.
bonnelover
i just put the good coil in the bad spot and no fire, and now the no fire coil is firing in the good spot, i guess i will try the icm and hopefully that is it
05 SLE
November 2010 COTM
mefloump
Year and Trim: 2001 SLE
Post by mefloump »
1 thing you could have tried before buying a new coil was to swap it with one of the other ones. If it moves with the coil, then the coil is bad. If it doesn't then the ICM is bad. Just my 2 cents.
'01 Bonneville SLE
'93 Grand Prix SE Coupe 3.4L Twin dual overhead cam
bonnelover
was no big deal, the part's place took it back. hopefully, today, i will try the ICM
05 SLE
November 2010 COTM
bonnelover
thanks for everyone's help, i replaced the ICM and she is back up and running!!
thanks again!!
05 SLE
November 2010 COTM
crash93ssei
Good to hear all is well again :)
xdhd350
Year and Trim: 2001 SSEi Silver Mist Metallic
Post by xdhd350 »
redzmonte wrote:Cats have a 8yr 80K mile warranty
Just to take that a step further... ALL EMISSIONS RELATED COMPONENTS have a federally mandated 80k warranty. There should be a list in the back of the owner's documents that lists all the components covered by the emissions warranty. Many dealerships will happily charge customers who don't know any better.
Greg
