Solid front motor mount
AnthonySSEi
- Year and Trim: 2001 SSEi
ive replaced the front mount twice in the past year, do you get any vibration with the solid motor mount, sry if this in the wrong section.
- Pontiacdad
- Retired Gearhead
- Year and Trim: 2000 SSEi
Re: Solid front motor mount
Yes you do get some vibration with the mount, as well as more torque steer on hard take off's.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
- Year and Trim: .
But, I am one of those guys who love it.Pontiacdad wrote:Yes you do get some vibration with the mount, as well as more torque steer on hard take off's.
You can always try it and if you don't like it you can put the original design in. All it costs is some hockey pucks and some threaded rod.
- wingman
- SSE Member
can anyone post pics of how to build the solid front motor mount with the hockey pucks???
CAI - PEMs - ZZP 2.5" DP - PLIM - 180* T-stat - AL605s - 245/50R16 - cleared front & rear corners - 20% tint - GXP strut brace
- harofreak00
I have since upgraded to the 01bonneSC style mount, just because it looks neater.jack car up, put jack stand under the engine/tranny and set jack back down... slightly.. enought to take tension off the mount... take off 3 bols on the mount, and 1 on the bottom, and remove all together
parts i picked up - pucks were $2.99 each and the bolt setup was $10
make a template to center your drill holes, however this is not really crucial
mark...
and drill...
put bolt thru
make sure everything is just as thick as the old mount
wrapped in electrical tape just for cosmetic
attach bracket in reverse order
leftovers that i can return to home depot... so about a $13 mod
ColoBonne
- Year and Trim: 2005 SE 180
It's ironic that I have to do something like this for my 2001 Bonny.
I've had to do something like this for my '63 Studebaker GT Hawk.
The original front mounts, while not liquid filled like the Bonny's, I kept destroying.
They were solid rubber, but with steel plates molded in on each end.
During hard launches, the driver's side front mount would torque so much that it would eventually tear the steel plate right off the rubber. To fix it, I had to do the same thing (kinda). I cut the mounting bolts off of a new mount, drilled a hole through the center, and ran a solid rod that I double nutted on both ends.
Hasn't been a problem now for going on 20+ years.
- Year and Trim: .
ColoBonne wrote:my '63 Studebaker GT Hawk
An important message:
- Wes
- Posts like a Northstar
- Year and Trim: 2002 Buick Park Ave
yourgrandma wrote:High
- wingman
- SSE Member
thanks again harofreak00 for the step by step pics!
bonne03ssei
- Retired Moderator
- Year and Trim: 2009 G8 GT
- Location: Central Canadicut • ONBF_03 x2 • ONBF_04 • NEBF_06 • NEBF_07 • ONBF_07 • NEBF_08
With the stock front mount there is a lot of movement of the engine under harder acceleration. With that movement the mount can start to tear apart, and cause more movement. The idea with the solid mount is to eliminate that front-to-back movement, transferring more power to the wheels. IIRC it is thought that some exhaust leaks around the downpipe area can be created by the front-to-back torquing of the engine under hard acceleration, because it all moves together.EWC88 wrote:Whats the purpose of doing the solid motor mount?
I did the mount last year and immediately afterwards I was not crazy about it. I noticed the vibrations right away and it didn't feel to 'pleasing.' But believe me, you'll get used to it and won't even notice anymore. It really isn't much of a vibration that you feel too much.
2003 Granite Metallic SSEi - 180,000 miles – All factory options
Essentials: rebuilt trans. w/ INTENSE shift kit | INTENSE FWI | INTENSE PCM | INTENSE drilled 180 t-stat | Aeroforce scan gauge
Goodyear Assurance TripleTreds | Energy Suspension endlinks
Exterior: cleared corners, cleared tails, red calipers, dual chrome exhaust tips
Interior: GXP steering wheel
