If I wanted to buy a scan tool...
Posted: Tue Aug 27, 2013 9:20 pm
by Bob Dillon
What would be a good one? I don't want the super-duper, double-throw-down gold-plated one, but I'd like to be able to record and print out data like the posts some here make, and view various sensors in real time.
I finally figured out how to use my buddy's Snap-on scanner, and even though it's old, it's *dang* handy. Christmas is coming, and the Little General can probably be induced to pop for one.
So what's a good, solid model for not all the money in the world?
Re: If I wanted to buy a scan tool...
Posted: Tue Aug 27, 2013 10:03 pm
by harofreak00
Any idea on budget?
I paid $800 for my Tech2, and it can do anything you want. I understand its a lot, but its probably cheaper than that Snap-on unit.
Posted: Tue Aug 27, 2013 10:08 pm
by Bob Dillon
harofreak00 wrote:Any idea on budget?
I was thinking 2-300, 400 tops.
Posted: Tue Aug 27, 2013 10:29 pm
by terrancew3
I've heard this was a fairly descent scan tool. Maybe you can find it somewhere else for less, but its in your price range. http://www.autozone.com/autozone/access ... 37646_0_0_
Posted: Wed Aug 28, 2013 12:06 am
by harofreak00
terrancew3 wrote:I've heard this was a fairly descent scan tool. Maybe you can find it somewhere else for less, but its in your price range. http://www.autozone.com/autozone/access ... 37646_0_0_
I had the 3160 before I got my Tech2. It was a good scan tool, especially doing the ABS codes and live view.
Posted: Wed Aug 28, 2013 12:19 am
by gmman
Amazon has the 3160 for $199 plus shipping.
Posted: Wed Aug 28, 2013 12:40 am
by gmman
question for harofreak00, does tech 2 read OBD 1 and 2 or just 2. since i have a 95 PA and a 96 SE, do i need both a tech 1 and 2. does an OBD 1 certified vehicle (my 95 PA) allow ABS and SRS data to be read with a tech 1 and/or tech 2.
thanks for any info you can provide on the subject.
PS i see that the 3160 does not read OBD 1 data (i think). you have to buy the 3140 for OBD 1 data (i think). but but the 3160 may be all that Bob Dillon needs.
by repinS
Since you are OBD2... if you or someone you know have an Android smartphone and $5... https://play.google.com/store/apps/deta ... rque&hl=en
Combined with this guy as a Bluetooth doohickey. Read/clear codes, AND you can view sensors real time and record data. You'll ring in well under $50. I've got one but paired it with a $5 Nokia app. Similar ones exist for iPhone and BlackBerry also. There are also other avenues where you can interface via USB to a laptop, but I haven't had first hand experience with those.
Posted: Wed Aug 28, 2013 8:54 am
by Bob Dillon
That is interesting. I do have an Android that is Bluetooth capable.
Hmmmm. :???:
Posted: Wed Aug 28, 2013 1:41 pm
by SSEBonne4evr
I bought an interface cable for my laptop, $18.
Can't tell you how many times I have used it on friends and family cars.
Uses scantool.net and you could read codes, analyze live sensor data and print.
does not do ABS codes though.
Here is some info on it when I used it on my 2010 Camaro.
http://www.camaro5.com/forums/showthread.php?t=124928
Posted: Wed Aug 28, 2013 3:24 pm
by 94SilverSSEi
Is there anyway to find out that it is a true tech 2 and not a chinese knock off? I have seen quite a few out there.
Posted: Wed Aug 28, 2013 3:58 pm
by harofreak00
No true way to tell unless you open them up and look at the motherboard.
I bought mine from a GM dealer that was going out of business, so I knew it was legit.
I don't have any experience with the fakes, but from my research if you are using them for older cars (pre-CANdi), they probably will still work fine. The problems arise with the newer vehicles.
Posted: Thu Aug 29, 2013 1:18 pm
by justhalc
Once I get my car back on the road and some money in my pocket, I'm going with the Torque app. I've heard nothing but positive reviews.
