SLE to GXP Spoiler Swap
Posted: Mon Jul 01, 2013 12:20 pm
by yonkerss
Is the SLE to GXP a direct bolt swap?
What tape should I use to tape on the end pieces of the gxp spoiler to the body?
Thanks!
Re: SLE to GXP Spoiler Swap
Posted: Mon Jul 01, 2013 12:41 pm
by WhiteArrow3800
Pretty sure the bolt holes are the same, though I haven't seen directly but I've never heard of anyone having to fill in or drill new holes.
As for the end pieces 3M makes a double sided tape for body panels. Should be able to find it at Autozone/Advance etc.
I've got to get on swapping my GXP wing on too...needs paint first though.
Posted: Mon Jul 01, 2013 4:01 pm
by 2003 SSEi
yup,
Holes are the same, red 3M double sided tape is how the sides are attached from the factory
Posted: Tue Jul 02, 2013 12:31 am
by yonkerss
Thanks guys!
Appears factory center portion of gxp wing has tape as well. Pat did u use this or just bolts on center portion?
Posted: Tue Jul 02, 2013 8:42 am
by 2003 SSEi
I just used the bolts for the center
Posted: Tue Jul 02, 2013 10:15 pm
by yonkerss
Thanks for the info Pat!
Posted: Sat Sep 28, 2013 9:56 pm
by 731Loadmaster
Are the wings allowing water to pass through, track off to the sides, or just pool. W-bodies had a modification using water hose rubber washers to allow rain/water to pass directly under the wing, or else water pooled on the trunk lid causing nasty gunk if left to sit for a few days.
Posted: Sun Sep 29, 2013 12:13 am
by younggunls1
731Loadmaster wrote:Are the wings allowing water to pass through, track off to the sides, or just pool. W-bodies had a modification using water hose rubber washers to allow rain/water to pass directly under the wing, or else water pooled on the trunk lid causing nasty gunk if left to sit for a few days.
It may get trapped under there or at least stay damp.. I used the 3m trim tape on the center section as well to seal it from water getting under it rather than just bolting it on and having a chance of it working it's way under
