shaking from front end on freeway
Posted: Thu Jun 27, 2013 9:14 am
by 95se
ok so from 60-70mph my steering wheel will shake and feel sloppy it does it the majority of the time but sometimes it feel completely fine with no shaking? any ideas guys?
thanks! :bluetwitch:
Re: shaking from front end on freeway
Posted: Tue Jul 02, 2013 2:51 pm
by 95se
Bump
Posted: Tue Jul 02, 2013 3:35 pm
by Jrs3800
I'd say balance issue, or a possible bad inner or out tie rod..
Posted: Tue Jul 02, 2013 4:16 pm
by 95se
Wheels are balanced and tie rods dont have any play
Posted: Tue Jul 02, 2013 4:39 pm
by reb
Warped rotors
Posted: Wed Jul 03, 2013 11:28 am
by RJolly87
Warped rotors would have been my next guess as well, and would explain the intermittent nature of the issue. Sometimes the brake pad is just touching a bit of the rotor, sometimes it pulls back far enough that it's not.
Posted: Thu Jul 04, 2013 12:34 am
by 95se
cant be that. the car shook when i got it, after i changed the rotors and pads it still did it. thats a good guess though.
Posted: Fri Jul 05, 2013 12:03 am
by MattStrike
Pop the strut tower caps off, and have a friend work the steering wheel back and forth. The strut mounts shouldn't move much more than 1/4". The next check is to make sure the struts are working (out of balance wheel plus a bad strut means the tire hops down the road).
Posted: Fri Jul 05, 2013 12:44 pm
by 95se
Thanks matt ill check on the play on those whenever it decides to stop raining around here
