Lookin for HID Setup?
Posted: Sun Jun 02, 2013 5:56 pm
Anyone have a post on here on how to hook HID
Or set up or anything please n thank you!
The forum for Pontiac Bonneville enthusiasts
http://pontiacbonnevilleclub.com/forum/
http://pontiacbonnevilleclub.com/forum/viewtopic.php?t=38983
Your answer = HIR2 (low beam), and HIR1 (high beam) bulbs.
A few posts above mentions Silverstars. Unless these are imported German Osram Silverstars (which I am 101% positive they're not), the Sylvania Silverstars sold here at Pep Boys are absolute smurfing garbage. I don't care what "experience" you have had with them, they're are absolute horse manure!
Here are the cold hard facts about regular 9006/9005 bulbs and a Silverstar 9006/9005 bulbs (I posted these in the Lighting thread in the general area a week or so ago);
Your stock bulbs are 9005 (high beam), and 9006 (low beams)
9006 Lumen Output: 1,000 lumens
9006 Kelvin Rating: 3,100k
Life: 1,000 hours
9005 Lumen Output: 1,700 lumens
9005 Kelvin Rating: 3,100k
Life: 320 hours
Now, here are the Silverstar specs;
9006 Lumen Output: 1,000 lumens (the same as the stock 9006)
9006 Kelvin Rating: 4,000k
Life: 200 hours
9005 Lumen Output: 1,700 lumens (the same as the stock 9005)
9005 Kelvin Rating: 4,000k
Life: 100 hours
Silverstar Ultra's
9006 Lumen Output: 1,000 Lumens (same as stock)
9006 Kelvin Rating: 4,100k
Life: 200 hours
9005 Lumen Output: 1,700 lumens (same as stock)
9005 Kelvin Rating: 4,100k
Life: 100 hours
So... to sum up this little excercise, all Silverstars are, are blue tinted capsules. In order to maintain the OEM level of lumen output, they OVERDRIVE the filament in the capsule. This overdriving of the filament leads to a Silverstar having the shelf life of a loaf of bread. This means, you LOSE 800 hours of light bulb life between low beams and 220 hours of life between high beam bulbs. But because of the increased kelvin output due to the color capsule, you *think*, you're seeing more and "whiter" light. YOU'RE NOT! All you're doing is changing the light color temperature. Otherwise you're still putting out the same actual output (as measured in lumens). Because you "think" you're seeing more and that they're brighter due to the illusion of the color temperature, when they burn out in a week, you run back to Autozone or wherever and plop down another $30, $40, or $70 for another set, rinse and repeat. These are not my opinions, these are facts provided by Sylvania.
Silverstars are garbage! Repeat after me... SILVERSTAR'S ARE GARBAGE... Save your money, buy the regular bulb... it has the IDENTICAL output! Or if you want more lumen output, buy a set if HIR bulbs. Here are the HIR stats;
HIR2 Lumen Output: 1,875 lumens (or an 875 lumen increase over a stock 9006 bulb)
HIR2 Kelvin Rating: 3,600k (or a 500k improvement over a stock 9006 bulb)
Life: 800 hours
HIR1 Lumen Output: 2,500 lumens (or an 800 lumen increase over a stock 9005 bulb)
HIR1 Kelvin Rating: 3,600k (or a 500k improvement over a stock 9005 bulb)
Life: 300 hours
To sum up, vs. the low beams, these provide 875 more lumens of output vs. the stock bulbs or Silverstar (garbage) bulbs, you only pay a 200 hour penalty (but that's 600 hours MORE than the Silverstar crap), are a 500k higher than stock bulbs and about 400 - 500 k less than the Silverstar (garbage) bulbs (depending on the Silverstar crap you go with). Similar increases are to be had vs, the high beam bulbs too!
Don't waste time with freaking Silverstars!
