Idling issues and hard shift
Posted: Mon Apr 22, 2013 12:36 pm
About a week or two after i got my L67 swap done I started coming across a couple issues..
When the engine is cold, it likes to idle at like 1200 for a while before it comes back down (longer than it should i think)
Then when the trans is cold, it shifts so hard from park to drive it feels like the tires are cheerping on the ground. But it only does it from park to drive (or reverse) not from first to second or on through the gears.
Another thing is when the car is at operating temp and is sitting idling, it miss fires and sometimes even throws a code.
I think the shift issue is because of a bad front motor mount (hockey puck one) and the high idle. Causing the engine to rock, but im not sure why its miss firing at operating temp. I put in a new pcv, plugs, coil packs, and wires. I also tried cleaning the idle air control valve with no luck.
Could it be a issue with the programming on the zzp pcm?
To keep in mind the car is cat less so maybe that's causing an issue? Also on a cold start up the supercharger sounds like its sucking in a ass ton of air until the idle comes down and it smooths out. Not sucking in a lot of air like a whine but more like there's a vacuum leak or something.
I have reason to believe its running to rich is because im getting pretty bad gas mileage.. like 20 on the high way bad.
Please help guys im so stumped!! thanks!
