Page 1 of 2
The Hail Mary Trans Build
Posted: Wed Apr 17, 2013 9:47 am
by 2003 SSEi
I have and this trans in about a year, and only put about 3,000 miles on it. I figured that id throw this up there so everybody could see the build that i did
So over the Past few weeks I have been building a bad ass trans because of the 2nd IS breaking on me.
Specs of the Build
2003 4t65e
Meziere billet flex plate
Intnese 300m Input shaft
Chrome Moly Pump shaft
Precision 3000 Stall Converter
Valve body and Channel Plate Modified by TEP
GMR 1' Chain 3.29
GMR Torsen Diff
Hardened 4th Gear
Raybestos Stage 1 for Input and 2nd Gear
Raybestos Z pack for 3rd Gear
Raybestos High Energy 4th Gear.
Intense Shift kit
So its been over a year of babying the car. I first Broke my Stock Trans back 2 days before Christmas 2010. Sucked.
so the trans had to come out
fast forward to June 2011 and I was hearing weird sounds and issues........
Here is what I found
So ya that Trans came out in September
and replaced with a GM SRTA that i happened to come across at a great price.
Fast forward to March 2012
kaboom, broke the stock IS in the GM SRTA trans......so that leads to the epic build.
so i took a nice tag along ride and dropped it off here at work
and Started the trans removal
Makes it nice to have access to this stuff
Started with the Stock 03 trans what had about 66K on when the IS let go.
notice the goodyness in the top of the pic
Found that there are actually output shafts that are used in the 4t65. one is slightly longer
and also the longer one also has a rib. its supposedly marked as the HD version, but I am unable to confirm 100%
Intense 300m Input Shaft
also the reluctor of the GMR set was Bolted by the previous installer
Welded it so it never becomes a problem.
I decided to go with the Raybestos Frictions and Steels over the Borg Warner after spending alot of time on the phone with the companies.
I went with the Stage 1 Red's for Input, and 2nd. Raybestos Z pack for 3rd and Raybestos High Energy for 4th.
Input (5 clutches instead of the stock 4)
Here is the Input module assembled (friction and steels)
Second Gear (added a thicker steel to get the tolerance tighter)
Second gear module
Third gear Z pack Module
Fourth Gear
Fourth Gear Module
Also have a modified 3rd gear clutch piston installed in the drum. Its from the 4T60 Trans and has more surface area and is alittle taller to provide the additional clamping force
i dont have pics of the build because its nothing really special, but i did have to take a pic of the GMR one last time.
So after it was all together I modified the rear trans mount with some "poly". As most of you know there is nothing made for some old person Bonneville, so you have to improvise.
New stock Mount
and fillling it in
new compared to the old stocker
Also filled in the Drivers side Trans mount with the "poly"
Once the Trans was out, switched the flex to the Meziere Billet unit
As an FYI i also tightened the rear cover bolts. as with every 3800 they were loose
Also while the trans was out, figured that i would make it pretty. Some rattle can to match the SC and the IC, that was painted in the past.
Installed the false KR kit or whatever, Put a nice blanket on the Case and wrapped the KR sensor too
Final part finned AL pan
After all this crap had 2 minor issues, got them resloved,
took the car out.......it was amazing
Re: The Hail Mary Trans Build
Posted: Wed Apr 17, 2013 10:28 am
by MattStrike
... where did you find that chain?
Posted: Wed Apr 17, 2013 10:32 am
by 2003 SSEi
MattStrike wrote:... where did you find that chain?
I knew a guy that was demodding his Turbo Car. I also have the GMR Diff too
Posted: Wed Apr 17, 2013 2:30 pm
by 95naSTA
That's about as legit as it gets. Nice build.
Posted: Wed Apr 17, 2013 2:47 pm
GMR as in Torsen LSD? Nice build, that's awesome.
Posted: Wed Apr 17, 2013 3:38 pm
by 2003 SSEi
00Beast wrote:GMR as in Torsen LSD? Nice build, that's awesome.
yes sir
Posted: Wed Apr 17, 2013 4:24 pm
by nubuilder
Very nice build!
I wish I had the guts to pull my trans apart.
Posted: Wed Apr 17, 2013 8:16 pm
by bs009
Looks like a solid build. I hope that LSD lasts for you, I haven't heard anything good about LSD's for the 4t65e at all.
Posted: Wed Apr 17, 2013 10:37 pm
by yourgrandma
We gotta hang out, Pat.
I think I have the raebestos/stage 1 stuff in mine. I also cheaped out and got a zzp input shaft.
I had to chuckle because the first 4 parts on your list are such a huge pile of money.
Posted: Wed Apr 17, 2013 11:06 pm
by MattStrike
Yeah, so do you have slips or a dyno sheet as well?
Posted: Wed Apr 17, 2013 11:23 pm
yourgrandma wrote:I had to chuckle because the first 4 parts on your list are such a huge pile of money.
That and the Torsen...
Posted: Thu Apr 18, 2013 7:29 am
by 2003 SSEi
bs009 wrote:Looks like a solid build. I hope that LSD lasts for you, I haven't heard anything good about LSD's for the 4t65e at all.
LOL the Torsen LSD is the GM Racing Unit, it will out last the car.
MattStrike wrote:Yeah, so do you have slips or a dyno sheet as well?
Yes i do. The video should explain everything :btruestory:
http://www.youtube.com/watch?v=KAPQZZPjivo
12.80@108, 313 WHP
Posted: Thu Apr 18, 2013 6:25 pm
by deano55
what tires are on the front?
Posted: Thu Apr 18, 2013 9:51 pm
by MattStrike
Nice. I bet a lot of people don't expect that.
Posted: Thu Apr 18, 2013 10:24 pm
by 2003 SSEi
deano55 wrote:what tires are on the front?
for the track they are a Nitto 555R Drag Radial. This year i am switching to Hoosier Quick Time Pro Slicks
Posted: Fri Apr 19, 2013 12:49 am
by Jfridge92
That video is not headphone user friendly @1:00 hahaha. Sick build Pat!
Posted: Sat Apr 20, 2013 2:01 am
by th3fr4nchi5e
Wow, nice build! That thing real gets up and goes!
Posted: Sat Apr 20, 2013 7:44 am
by Jfridge92
I bet that dude in the Challenger *shoot* his pants when he got his doors blown off by a grandma car. Even though the way yours looks it's far from that hahaha.
Posted: Sat Apr 20, 2013 6:41 pm
by yourgrandma
Maybe I missed it, but what final drive ratio do you have? I really wish I would have done a gear swap when I did the input shaft. I imagine that would be helpful in keeping the rest of the trans alive. Just couldn't decide on a specific ratio.
Posted: Sun Apr 21, 2013 8:15 am
by Jrs3800
Pat, would those Clutches work in a 4T60E?
