2005 Grand Prix (Base) question
- terrancew3
- Posts like an LN3
- Year and Trim: 2009 G8 GXP
So my girlfriend has an '05 GP, and every time she starts it, the car revs up and then goes real low and then goes up to normal. It does it on electric start and with the key. Im not positive what it is, but to me it seems like a sensor is going bad (possibly a TPS or Idle sensor?). Has anyone with a GP ever had this issue? I think because of this, her electric start doesn't always stay running and just quits cause the idle gets real low for that instant. If I can figure this out, I wanna fix it for her. No codes are thrown either.
2000 SSEi *sold 9/27/15* December '12 & May '15 COTM
2005 Grand Prix
2009 G8 GXP #418 of 1,829 November '15 TOCOTM
2005 Grand Prix
- nos4blood70
- Year and Trim: 2003 SLE
Re: 2005 Grand Prix (Base) question
How many miles? You can clean up all the sensors in the TB like the Idle Air control sensor.
- terrancew3
- Posts like an LN3
I think somewhere around 106,000. What would I clean them with?nos4blood70 wrote:How many miles? You can clean up all the sensors in the TB like the Idle Air control sensor.
2005 Grand Prix
2005 Grand Prix
- nos4blood70
Some MAF sensor cleaner. I wouldn't put something as harsh as TB cleaner on them.
- FasGP
- GXP Member
- Year and Trim: Pullied Clean 2k Black SSEi...
My 05 does this also for the last year, but I have not had time to troubleshoot. I am sure the IAC valve is a bit sticky, but my intention was to clean up all on the TB....
MAF cleaner only. This is a common issue on the drive by wire design...
- terrancew3
- Posts like an LN3
Someone on the GP forum told her its a good possibility that the IAC is stuck, but Idk where that even is on her car. Anyone got a detailed diagram of that?FasGP wrote:My 05 does this also for the last year, but I have not had time to troubleshoot. I am sure the IAC valve is a bit sticky, but my intention was to clean up all on the TB....
2005 Grand Prix
2005 Grand Prix
- haro1225
- Posts like a Northstar
- Year and Trim: 2004 GTO
I think its part of that electronic box on the TB, and I'm not sure if that can even be cleaned, or if the whole unit would need to be replaced.
-Ryan
2013 Audi Allroad Quattro
yourgrandma wrote:Hi.
- terrancew3
- Posts like an LN3
Yeah, I saw that when I was changing her plugs and wires last night. I couldn't quite figure out how that comes apart.haro1225 wrote:I think its part of that electronic box on the TB, and I'm not sure if that can even be cleaned, or if the whole unit would need to be replaced.
2005 Grand Prix
2005 Grand Prix
- FasGP
- GXP Member
I don't have a diagram, but it is a spring loaded unit. I sprayed a carb cleaner in a small metal cup and soaked it. I know there must be a way it comes apart, but I have always broken them. Most times, a soaking, wiping and cycling it numerous times in your hand will free it up and make it work again.
- terrancew3
- Posts like an LN3
Could I just spray a cleaner into the throttle body while its running, and hope that frees stuff up?FasGP wrote:I don't have a diagram, but it is a spring loaded unit. I sprayed a carb cleaner in a small metal cup and soaked it. I know there must be a way it comes apart, but I have always broken them. Most times, a soaking, wiping and cycling it numerous times in your hand will free it up and make it work again.
2005 Grand Prix
2005 Grand Prix
- FasGP
- GXP Member
No, the IAC control and spring parts sit behind a small top hat shaped head, inside a passage in the TB. There is two little screws...just remove them, and wiggle it very gently to take it out. Put a bit of grease on the seal when you put it back in and make sure it doesn't get damaged during removal or install.terrancew3 wrote:Could I just spray a cleaner into the throttle body while its running, and hope that frees stuff up?FasGP wrote:I don't have a diagram, but it is a spring loaded unit. I sprayed a carb cleaner in a small metal cup and soaked it. I know there must be a way it comes apart, but I have always broken them. Most times, a soaking, wiping and cycling it numerous times in your hand will free it up and make it work again.
- terrancew3
- Posts like an LN3
Yeah, her TB doesn't look anything like that. That setup is how mine looks. When she comes over, I will take a picture and upload it on here.FasGP wrote: No, the IAC control and spring parts sit behind a small top hat shaped head, inside a passage in the TB. There is two little screws...just remove them, and wiggle it very gently to take it out. Put a bit of grease on the seal when you put it back in and make sure it doesn't get damaged during removal or install.
2005 Grand Prix
2005 Grand Prix
- terrancew3
- Posts like an LN3
For that IAT, is that what that extension wire is for? So when you install a aftermarket intake, you can extend the sensor closer to the filter?
2005 Grand Prix
2005 Grand Prix
- haro1225
Is this what you have? (sorry for the crappy phone pic).
-Ryan
- FasGP
- GXP Member
Whoa...completely forgot about the drive by wire design...not sure where my brain is lately.haro1225 wrote:Is this what you have? (sorry for the crappy phone pic).
These do not have IAC...that function is electronically controlled via the PCM adjusting the plate in the TB. More than likely, the throttle body and/or MAF is very dirty. Something is not reading correct air flow due to sensor contamination, or restriction.
Sorry to send OP on a tangent...looking for parts that don't exist...
- terrancew3
- Posts like an LN3
Yes it looks like that 2nd picture. I am are gonna order a new MAF today, so if that doesnt fix it there is something wrong somewhere else. All the plugs wires are replaced with AC/Delco iridium plugs and wireset. Maybe it could be a faulty coil pack? I guess we'll see when the MAF gets here.
2005 Grand Prix
2005 Grand Prix
You may want to try cleaning the MAF before spending good money on a new one. Also, check for a vacuum leak or possible loose intake tube or air cleaner housing. A vacuum leak would cause the exact issue that you described. The leak would cause the hi idle until the PCM could correct it to the pre set RPM.
- terrancew3
- Posts like an LN3
Well, for 50 bucks its not a huge deal to pick up a new one. But I know I changed the air filter when she first got it, and it didnt do that back then. I told her she should get the CAI for it, to help with air flow and engine performance.
2005 Grand Prix
2005 Grand Prix
- terrancew3
- Posts like an LN3
Turns out it was just a real dirty MAF. Sprayed some cleaner in the TB, and so far it's solved the issue. We'll see how it goes for the next few weeks.
2005 Grand Prix
2005 Grand Prix
